I am migrating skin.helper.service.widgets, and I am running into this issue with arrow:
xml:
2019-12-22 16:46:30.300 T:17192 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'AttributeError'>
Error Contents: 'bytes' object has no attribute 'tzinfo'
File "C:\Program Files\Kodi\addons\script.skin.helper.widgets\plugin.py", line 9, in <module>
import main
File "C:\Program Files\Kodi\addons\script.skin.helper.widgets\resources\lib\main.py", line 17, in <module>
from metadatautils import MetadataUtils
File "C:\Program Files\Kodi\addons\script.module.metadatautils\lib\metadatautils.py", line 9, in <module>
import helpers.kodi_constants as kodi_constants
File "C:\Program Files\Kodi\addons\script.module.metadatautils\lib\helpers\kodi_constants.py", line 9, in <module>
from .utils import KODI_VERSION
File "C:\Program Files\Kodi\addons\script.module.metadatautils\lib\helpers\utils.py", line 13, in <module>
import arrow
File "C:\Program Files\Kodi\addons\script.module.arrow\lib\arrow\__init__.py", line 3, in <module>
from .api import get, now, utcnow
File "C:\Program Files\Kodi\addons\script.module.arrow\lib\arrow\api.py", line 10, in <module>
from arrow.factory import ArrowFactory
File "C:\Program Files\Kodi\addons\script.module.arrow\lib\arrow\factory.py", line 19, in <module>
from arrow.arrow import Arrow
File "C:\Program Files\Kodi\addons\script.module.arrow\lib\arrow\arrow.py", line 1396, in <module>
Arrow.max = Arrow.fromdatetime(datetime.max)
File "C:\Program Files\Kodi\addons\script.module.arrow\lib\arrow\arrow.py", line 217, in fromdatetime
if dt.tzinfo is None:
AttributeError: 'bytes' object has no attribute 'tzinfo'
I am using the latest arrow version, 0.15.5. Any ideas? Thank you for any help provided.
Regards,
Bart
(2019-12-22, 23:00)ronie Wrote: [ -> ]it's a known issue when using kodi + arrow on windows.
kodi devs are looking into it.
https://github.com/crsmithdev/arrow/issues/738
ronie, thanks! It seems that issue is closed. Razzee seemed to think it was an implementation issue on his end, so he asked to close the issue. Is this still being looked at? In my case, it seems that datetime.max returns an object type of 'bytes' in Windows 10.
Regards,
Bart
(2019-12-22, 23:07)bsoriano Wrote: [ -> ] (2019-12-22, 23:00)ronie Wrote: [ -> ]it's a known issue when using kodi + arrow on windows.
@ronie, thanks! It seems that issue is closed. Razzee seemed to think it was an implementation issue on his end, so he asked to close the issue. Is this still being looked at? In my case, it seems that datetime.max returns an object type of 'bytes' in Windows 10.
Regards,
Bart
I don't think it's on my end. Which means arrow. I think it's somewhere in kodi's python 3 implementation on windows.
ronie, @
Razze, any updates on the issues of arrow in Windows? Until this gets solved I cannot progress in migrating tv.show.next.aired to python 3. Thanks for your help.
Regards,
Bart
(2019-12-29, 14:01)bsoriano Wrote: [ -> ]@ronie, @Razze, any updates on the issues of arrow in Windows? Until this gets solved I cannot progress in migrating tv.show.next.aired to python 3. Thanks for your help.
Regards,
Bart
It feels like the colleague looking into this is stuck. Or we are looking in the wrong place. Not sure if he had any more success @
Paxxi
Apologies if not relevant. But I am using Kodi v19 on Windows and I am seeing this error when I install the Trakt.tv addon:
log:
2021-03-09 16:15:10.930 T:15512 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'ModuleNotFoundError'>
Error Contents: No module named 'queue'
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.trakt\default.py", line 6, in <module>
from resources.lib.service import traktService
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.trakt\resources\lib\service.py", line 20, in <module>
from resources.lib.traktapi import traktAPI
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.trakt\resources\lib\traktapi.py", line 17, in <module>
from trakt import Trakt
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.trakt\lib\trakt\__init__.py", line 3, in <module>
from trakt.client import TraktClient
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.trakt\lib\trakt\client.py", line 5, in <module>
from trakt.core.http import HttpClient
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.trakt\lib\trakt\core\http.py", line 9, in <module>
from trakt.core.request import TraktRequest
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.trakt\lib\trakt\core\request.py", line 3, in <module>
from requests import Request
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\__init__.py", line 43, in <module>
import urllib3
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\__init__.py", line 7, in <module>
from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\connectionpool.py", line 28, in <module>
from .packages.six.moves import queue
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 91, in __get__
result = self._resolve()
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 113, in _resolve
return _import_module(self.mod)
File "C:\Users\myusername\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 82, in _import_module
__import__(name)
ModuleNotFoundError: No module named 'queue'
Thats a different issue. Looks like the queue module wasnt built for the windows libs. @
Paxxi hopefully can have a look.
Hi All,
I would like to comment that it is not just Windows that shows this issue.
I'm on Linux, Ubuntu 20.04 and have the same error, which causes Kodi to crash after the error.
Some Details:
Quote:Kodi compiled 2021-02-19 by GCC 9.3.0 for Linux x86 64-bit version 5.4.78 (328782)
Running on Ubuntu 20.04.2 LTS, kernel: Linux x86 64-bit version 5.4.0-562012221313-generic
Using arrow version 0.15.5, I get the following error:
Quote:2021-03-29 20:07:53.670 T:8844 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'datetime.timedelta' object has no attribute 'tzinfo'
File "/home/mediapc/.kodi/addons/script.skin.helper.service/plugin.py", line 10, in <module>
from resources.lib.plugin_content import PluginContent
File "/home/mediapc/.kodi/addons/script.skin.helper.service/resources/lib/plugin_content.py", line 22, in <module>
File "/home/mediapc/.kodi/addons/script.module.metadatautils/lib/metadatautils.py", line 10, in <module>
File "/home/mediapc/.kodi/addons/script.module.metadatautils/lib/helpers/kodi_constants.py", line 11, in <module>
File "/home/mediapc/.kodi/addons/script.module.metadatautils/lib/helpers/utils.py", line 13, in <module>
import arrow
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/__init__.py", line 3, in <module>
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/api.py", line 10, in <module>
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/factory.py", line 19, in <module>
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 1396, in <module>
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 217, in fromdatetime
AttributeError: 'datetime.timedelta' object has no attribute 'tzinfo'
I updated Arrow to the latest (1.03) and got a slightly different error, but along the same lines:
Quote:2021-04-01 12:00:24.138 T:9529 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'datetime.timedelta' object has no attribute 'timestamp'
import arrow
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/__init__.py", line 2, in <module>
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/api.py", line 12, in <module>
from arrow.arrow import TZ_EXPR, Arrow
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 34, in <module>
from arrow import formatter, locales, parser, util
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/parser.py", line 26, in <module>
from arrow.util import next_weekday, normalize_timestamp
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/util.py", line 6, in <module>
from arrow.constants import (
File "/home/mediapc/.kodi/addons/script.module.arrow/lib/arrow/constants.py", line 16, in <module>
_MAX_TIMESTAMP = datetime.max.timestamp()
AttributeError: 'datetime.timedelta' object has no attribute 'timestamp'
Quite happy to open a GitHub issue if you point me in the right direction.
(2021-04-01, 04:59)Wanilton Wrote: [ -> ]@RB0135
Install one updated version, thanks to Angelinas. It fixes the issue.
http://files.xbmcbrasil.net/Scripts/scri...trix.1.zip
Check here the fix
https://github.com/arrow-py/arrow
Wanilton - Thanks for the link, but that was the version I was using when I mentioned in my post 0.15.5. I will re-install it just the same to see what happens.
I have noticed recently some developers are bringing out fixes in modules, but not changing the version number.. Makes it hard to keep up sometimes..
(2021-04-01, 05:40)Wanilton Wrote: [ -> ] (2021-04-01, 05:29)RB0135 Wrote: [ -> ] (2021-04-01, 04:59)Wanilton Wrote: [ -> ]@RB0135
Check here the fix
@Wanilton - Thanks for the link, but that was the version I was using when I mentioned in my post 0.15.5. I will re-install it just the same to see what happens.
Yes, it´s the same version number, but contains the fix. I only post here, the fix was included by angelinas. Tested in windows, and solve the trouble.
Bump the version to 0.15.6
Great... Thanks for that.. Will try later tonight.
