Full Version: ERROR: CPVRTimerInfoTag:
I have Kodi installed on a Windows PC & have just started to experiment with LibreElec. On both OS's I see repeated errors reported in the logs that look like this:
2019-12-22 14:51:54.678 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (2)!
2019-12-22 14:51:54.679 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (4)!
2019-12-22 14:52:55.301 T:1534059392   ERROR: Previous line repeats 9 times.
2019-12-22 14:52:55.301 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (2)!
2019-12-22 14:52:55.302 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (4)!
2019-12-22 14:53:55.895 T:1534059392   ERROR: Previous line repeats 9 times.
2019-12-22 14:53:55.895 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (2)!
2019-12-22 14:53:55.895 T:1534059392   ERROR: CPVRTimerInfoTag: No epg tag given for epg based timer type (4)!
2019-12-22 14:53:59.333 T:1534059392   ERROR: Previous line repeats 9 times.
The errors are much more frequent on LibreElec & are filling the log file to such an extent that it has grown to over 500kB in 24hrs. I have now had to disable all logging.
I am running Leia V18.5 on LibreELEC 9.2.0 on a Raspberry Pi 3B. Vbox 3442 is running XTI_VJ.2.65
The error happens when there is no value EPG ID for a timer.
Just delete the old timers and I would imagine it will go away.
I think you can reduce the spam by changing activetagcheckinterval in advancedsettings.xml.
Martin
