(2019-12-23, 22:42)Roby77 Wrote: [ -> ]Since libreelec my setup is affected by black screen issue on start/stop of a movie with adjust to refresh rate on
it's a well known problem with denon avr + intel box
A solution that works for 90% is to set gui at 30hz
some example of other users affected by this problem
https://forums.plex.tv/t/automatic-frame...een/164742
or here
https://forum.kodi.tv/showthread.php?tid=220277
I have a Denon X2000, could someone confirm with a more recent denon avr problem is solved ?
I had the issue with a Denon AVR-E400, but it's been working fine with a Denon AVR-X4400H.
My workaround on Intel with the Denon AVR-E400 was to edit the EDID to remove the 10-bit and 12-bit color modes, and force the custom EDID by a kernel parameter. The Intel driver negotiates the higher 12-bit color mode even though the source information in X11 is only 8-bit. I noticed the problem only when changing refresh rates with the higher bit rate required for the 12-bit color modes, or for 4K@30 Hz. Keeping it 1080p at 8-bit color or below, and I didn't have the problem.
I didn't have the problem with an integrated Nvidia GT520 GPU on an old Intel Atom Machine. That GPU only negotiated 8-bit color, and wouldn't do 4K which is probably why.
With the Denon AVR-X4400H, I haven't had to edit the EDID. It works fine with the newer Intel GPU.
(2019-12-23, 23:15)yasij Wrote: [ -> ] (2019-12-23, 22:42)Roby77 Wrote: [ -> ]Since libreelec my setup is affected by black screen issue on start/stop of a movie with adjust to refresh rate on
or here
Do you rembember which program you used to edit edid table ?
last time i used getedid command instead of old guide >https://wiki.libreelec.tv/custom_edid#tab__intel But i can't find anymore the firmware folder in libreelec where edid is stored
thank you for your suggestion
(2019-12-23, 23:57)Roby77 Wrote: [ -> ] (2019-12-23, 23:15)yasij Wrote: [ -> ] (2019-12-23, 22:42)Roby77 Wrote: [ -> ]Since libreelec my setup is affected by black screen issue on start/stop of a movie with adjust to refresh rate on
or here
I read the standard and used a hex editor (xxd). See
331638.
So finally i tried
I report my experience for other people
Tried to edit with AW EDID Editor but the switch to 1.4 edid profile messed up other paramaters (video parameters) so I used Deltacast edid editor that have also an hex editor that auto fix checksum
I'm really frustrated
Ok it's a Denon hardware bug ( reclock problem chip )
But I can't solve it
Edited edin to support only 8bit
Tried other HDMI cable & combination
I continue to experience black screen issue on start stop
How can I check if I forced 8 bit if video card is negotiating correctly 8 bit
I see that other user refer to
drm:intel_hdmi_compute_config [i915]] picking bpc to 8 for HDMI
Where I can check it ?
When I will have money I will change this shit avr
ok drm debug activated and verified that bpc is set to 8
[drm:intel_hdmi_compute_config] picking 8 bpc for HDMI output (pipe bpp: 24)
never ending story
Ok update for community
Problem : with autoframerate switch I get black screen on start or stop of a film
Denon x2000 HDMI 1.4
Tv Panasonic vt60
HDMI cable expensive and tried other cable
Beebox Intel n3150 but I didn't remember if Chromebox had this problem
Read somewhere that the problem is an hardware bug of Denon
Solution tried:
Captured edid
Modify edid to force 8bit
Checked with dmseg that bpc was set to 8
Checked via avr that bpc is 8
Still have problem so cause is not waf compliant I set gui to 24 and leave autoframerate switch on
Probably not a good solution but is the best solution until I will change my avr
