Could not find the thread, but someone asked if devices based on the Amlogic S905X3 can play Netflix in 1080p, it DOES. Felipejfc on Freaktab pointed out that CoreELEC is now supported for this SoC.
I tested this CoreELEC OS on my Beelink GT1 Mini2 (Beelink provided me), and yes, I was amazed that it was able to play Netflix in 1080p with DD+ audio... I thought it would be limited to only 720p.
Nice! Next stop, 4k & Atmos :-)
(2019-12-24, 17:23)clarkss12 Wrote: [ -> ]Could not find the thread, but someone asked if devices based on the Amlogic S905X3 can play Netflix in 1080p, it DOES. Felipejfc on Freaktab pointed out that CoreELEC is now supported for this SoC.
Hi, Did netflix addon on CoreELEC OS require download chrome OS Widevine L1 and inputstream.adaptive add-on. And could you screen short when play netflix with Code info by press O on keyboard. Sorry my bad English. Thanks so much
(2019-12-25, 03:38)sogoku_vn Wrote: [ -> ] (2019-12-24, 17:23)clarkss12 Wrote: [ -> ]Could not find the thread, but someone asked if devices based on the Amlogic S905X3 can play Netflix in 1080p, it DOES. Felipejfc on Freaktab pointed out that CoreELEC is now supported for this SoC.
Yes, it required the Chrome OS download..... and installed the inputstream.adaptive.
https://www.dropbox.com/preview/dropbox%...e=personal
(2019-12-25, 05:14)clarkss12 Wrote: [ -> ] (2019-12-25, 03:38)sogoku_vn Wrote: [ -> ] (2019-12-24, 17:23)clarkss12 Wrote: [ -> ]Could not find the thread, but someone asked if devices based on the Amlogic S905X3 can play Netflix in 1080p, it DOES. Felipejfc on Freaktab pointed out that CoreELEC is now supported for this SoC.
Play netflix FHD 1080p smoth and CPU usage ? Thanks
I hope the second Dropbox link worked. It shows the CPU usage.
(2019-12-25, 05:29)clarkss12 Wrote: [ -> ]I hope the second Dropbox link worked. It shows the CPU usage.
Oh, yeah. Not high CPU usage and not too hot cpu temp. Thank you so much, I will buy tanix tx3 s905x3 2/16gb. Is it good?
(2019-12-25, 05:38)sogoku_vn Wrote: [ -> ] (2019-12-25, 05:29)clarkss12 Wrote: [ -> ]I hope the second Dropbox link worked. It shows the CPU usage.
All 4 cores are running around 80% average while playing a 1080p movie.
(2019-12-25, 05:52)clarkss12 Wrote: [ -> ] (2019-12-25, 05:38)sogoku_vn Wrote: [ -> ] (2019-12-25, 05:29)clarkss12 Wrote: [ -> ]I hope the second Dropbox link worked. It shows the CPU usage.
while playing a 1080p movie,any lag, drop frames or sound faster than pictures
(2019-12-25, 06:00)sogoku_vn Wrote: [ -> ] (2019-12-25, 05:52)clarkss12 Wrote: [ -> ] (2019-12-25, 05:38)sogoku_vn Wrote: [ -> ]Oh, yeah. Not high CPU usage and not too hot cpu temp. Thank you so much, I will buy tanix tx3 s905x3 2/16gb. Is it good?
No dropped frames, runs smooth, DD+ audio and changed frame rate.
https://www.dropbox.com/sh/tpuakvvlbogx9...-YTPa?dl=0
(2019-12-25, 17:19)clarkss12 Wrote: [ -> ] (2019-12-25, 14:20)sogoku_vn Wrote: [ -> ] (2019-12-25, 05:26)clarkss12 Wrote: [ -> ]https://www.dropbox.com/s/9oeygxbcod7xeh...a.jpg?dl=0
How to display info (codec, cpu usage, temp) like your picture. Thanks
Depress 3 keys >> Shift, Ctrl, "o"
The pics are gone can you upload again? I think i have mine all working. Also I think atmos works isnt it carried on dolby digital +?
