Full Version: Kodi will not play back audio from DVD with PCM audio
I have a Human League Music Videos DVD . I made a DVD9 backup of the disk. The backup plays fine in VLC and the disk plays fine in a DVD Player.
When I launch the DVD image in Kodi the video plays back but audio does not play back. Going to Audio OSD menu says there are no audio tracks.
The disk has only PCM audio there are no other tracks.
MediaInfo reports the following (from ripped VOBs) :
General
Complete name                            : /MyPath/The Human League - The Very Best Of (Full DVD9)/VIDEO_TS/VTS_01_7.VOB
Format                                   : MPEG-PS
File size                                : 738 MiB
Duration                                 : 51s 716ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 120 Mbps
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : [email protected]main
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : M=3, N=15
Format settings, picture structure       : Frame
Duration                                 : 51s 151ms
Bit rate mode                            : Variable
Bit rate                                 : 116 Mbps
Maximum bit rate                         : 9 800 Kbps
Width                                    : 720 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 29.970 (30000/1001) fps
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 11.172
Stream size                              : 706 MiB (96%)
Audio
ID                                       : 189 (0xBD)-160 (0xA0)
Format                                   : PCM
Format settings, Endianness              : Big
Format settings, Sign                    : Signed
Muxing mode                              : DVD-Video
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Delay relative to video                  : -600ms
Stream size                              : 9.47 MiB (1%)
Truncated--------------------------------------
I checked the page at https://kodi.wiki/view/AudioEngine and it looks like PCM from a DVD should be supported.
Mark
File an issue on GitHub with Debug Log and sample if possible.
I don't have any issues with that DVD (The Human League - The Very Best Of). PCM track plays fine. Tested with Kodi master and 18.5.
Yeah as OP did not post any Debug Log - nothing we can do.
(2019-12-28, 20:28)smp1 Wrote: [ -> ]I don't have any issues with that DVD (The Human League - The Very Best Of). PCM track plays fine. Tested with Kodi master and 18.5.
Is that a Region 1 NTSC release?
Did you try the DVD or files extracted from DVD?
(2019-12-26, 09:49)fritsch Wrote: [ -> ]File an issue on GitHub with Debug Log and sample if possible.
Easier said than done. Too many rules on logs
(2020-01-02, 18:51)tekno Wrote: [ -> ]
NTSC R1. Extracted VIDEO_TS and also tried extracted iso image.
(2020-01-02, 18:52)tekno Wrote: [ -> ]Easier said than done. Too many rules on logs
There's only one rule and it's quite simple - if your device contains banned addons (wiki) then we don't support it...
