Full Version: Stutter when playing 23.976 material on Intel NUC8i3BEK
Problem: When playing back video material encoded in x264 (haven't tested any other), container mkv or mp4 etc. doesn't matter, with 23.976fps and having activated the sync monitor to video option, I get a very short  "jerk" every 4 seconds or so. When I deactivate that option, or playing material with other framerates, everything seems normal (of course 23.976 video doesn't look optimal when that option is deactivated, but at least I don't notice the regular stutter). I use VAAPI but deactivating it doesn't change the behavior.  I have my NUC connected to an A/V receiver via HDMI, having it connected directly to my TV also doesn't change anything. I updated the NUC's BIOS to the latest version 0077 from November 27th of this year, no change. There exists a HDMI Firmware Update Tool from Intel which only runs on windows. Since I don't have that installed I'm out of luck here, but I'm not convinced it might change anything because I think the problem is elsewhere see my musings below.
My setup:
  • Intel NUC8i3BEK, which is:
  • Intel Core i3-8109U @ 3.00GHz
  • 8GB RAM
  • Intel HD Graphics GPU (Coffeelake 3x8 GT3), according to kodi info using Mesa 19.0.8 driver
  • Running Kodi v18.5
  • on (L)ubuntu 19.04 Linux 5.0.0-37-generic x86_64
Suggestion:
After creating the kodi debug log I notice the following section which concerns the start of playback:
2019-12-26 17:47:17.506 T:139740522085056   DEBUG: ------ Window Init (VideoFullScreen.xml) ------
2019-12-26 17:47:17.506 T:139740522085056    INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
2019-12-26 17:47:17.510 T:139740522085056  NOTICE: Whitelist search for: width: 720, height: 544, fps: 23.976, 3D: false
2019-12-26 17:47:17.510 T:139740522085056   DEBUG: Trying to find exact refresh rate
2019-12-26 17:47:17.511 T:139740522085056   DEBUG: No exact whitelisted resolution matched, trying double refresh rate
2019-12-26 17:47:17.511 T:139740522085056   DEBUG: No double whitelisted resolution matched, trying 3:2 pullback
2019-12-26 17:47:17.511 T:139740522085056   DEBUG: No 3:2 pullback refresh rate whitelisted resolution matched, trying current resolution
2019-12-26 17:47:17.511 T:139740522085056   DEBUG: Matched current Resolution DP-1: 1920x1080 @ 23.98Hz (21)
2019-12-26 17:47:17.511 T:139740522085056  NOTICE: Display resolution ADJUST : DP-1: 1920x1080 @ 23.98Hz (21) (weight: 423625307979776.000)
So kodi chooses 23.98, which is not exactly 23.976, maybe that's what's causing the hiccups? I remember way back in the early days of kodi and of course with another hardware setup, having to edit some X config file to add a line to get real 23.976 output to my TV but I forgot what and where, maybe that would help?
debug.log: yirovecobi.kodi (paste)
Please post your Xorg.0.log - kodi's log does not show anything about a stutter.
(2019-12-26, 21:15)fritsch Wrote: [ -> ]Please post your Xorg.0.log - kodi's log does not show anything about a stutter.
Xorg.0.log
I don't understand why you have to enable the sync option. Your hardware is perfectly capable of outputting the "real" 23.976Hz.
Quote:[    13.189] (II) LoadModule: "modesetting"
[    13.189] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    13.190] (II) Module modesetting: vendor="X.Org Foundation"
[    13.190]     compiled for 1.20.4, module version = 1.20.4
Please switch to the intel xorg driver. You can find in the VAAPI howto, on how to do that.
(2019-12-27, 11:45)fritsch Wrote: [ -> ]
YES, that did it! Thank you very much. You guys rock.
And if you have the time. File a bug for the modesetting driver with the kernel people.
(2019-12-27, 13:34)gokudo Wrote: [ -> ]
Can you tell me where you found the VAAPI howto that shows how to switch to the intel xorg driver?
Thanks, UbuntuUser
(2020-01-05, 02:01)UbuntuUser Wrote: [ -> ]
(2019-12-27, 11:45)fritsch Wrote: [ -> ]Please switch to the intel xorg driver. You can find in the VAAPI howto, on how to do that.
Thanks, UbuntuUser
231955 (thread)
Important part is:
cd /etc/X11/xorg.conf.d/
sudo ln -s /usr/share/doc/xserver-xorg-video-intel/xorg.conf 10-intel.conf
