Full Version: UpNext - No longer working
The Up Next add-on has stopped working for me, and I was hoping someone could have a look at it please. I'm running Kodi 18.5 with a NextPVR back-end on another Windows 10 box.
The add-on used to work fine, but now it never does, and I usually get a pop-up instead just saying "Up Next Error: Check the log for more information".
My logs are below, split into 3 parts due to the size. I restarted Kodi and played one video file and skipped it to a minute before the end. Kodi actually then locked up when I tried to exit it, but that's never happened before and seems unrelated (maybe because debug logging was on?), and hopefully the log still has something useful to figure out why Up Next isn't working. Thanks
Logs:
https://paste.kodi.tv/zelajipufi.kodi
https://paste.kodi.tv/kilimuyuho.kodi
https://paste.kodi.tv/itakoxineg.kodi
(2019-12-28, 11:30)Banest Wrote: [ -> ]Hi,
Logs:
The pop up you're seeing is generated because the addon crashed.  In this case the error has to do with a missing control in a window.  There's a thread for UpNext where others are reporting something similar, so you might check there to see if the author of the addon is working on a fix.
https://forum.kodi.tv/showthread.php?tid=336747
Thanks mate, I'll post over in that thread and see how I go
