Full Version: Can't run Kodi (Microsoft Store Edition) with parameter
Hello Kodi team,
I installed Kodi from Microsoft Store.
I can run Kodi using the command line:
shell:AppsFolder\XBMCFoundation.Kodi_4n2hpmxwrvr6p!Kodi
But that does not support parameters (for example below command line not working)
shell:AppsFolder\XBMCFoundation.Kodi_4n2hpmxwrvr6p!Kodi "D:\Inside Out (2015).MKV"
The solution is $PATH folder
You must add Kodi to $PATH folder (like Python or iTunes)
The Kodi can then be run with a parameter:
%LocalAppData%\Microsoft\WindowsApps\Kodi.exe "D:\Inside Out (2015).MKV"
Thanks for your attention
