Full Version: Trakt plugin won't sync with my library
So I've been using trakt with Kodi on a windows machine for years, no problem.  Even tried having it sync on the windows machine earlier today to make sure it wasn't an issue with the trakt api itself.  I decided to set up a raspberry pi 4 running raspbian buster as a dedicated media center.  For some reason the trakt plugin just doesn't get any data to sync the watched status on my library in the new setup.  I've installed/uninstalled/reinstalled the trakt plugin multiple times, restarted kodi, rebooted the machine, reset my auth token for tract multiple times (both through kodi and by revoking access through the website)... nothing seems to work.  Any suggestions for what to try next would be more than welcome!
Here's the log file showing what's happening... https://paste.kodi.tv/qesafopevo.kodi
(2020-01-01, 00:08)m00kfu Wrote: [ -> ]So I've been using trakt with Kodi on a windows machine for years, no problem.  Even tried having it sync on the windows machine earlier today to make sure it wasn't an issue with the trakt api itself.  I decided to set up a raspberry pi 4 running raspbian buster as a dedicated media center.  For some reason the trakt plugin just doesn't get any data to sync the watched status on my library in the new setup.  I've installed/uninstalled/reinstalled the trakt plugin multiple times, restarted kodi, rebooted the machine, reset my auth token for tract multiple times (both through kodi and by revoking access through the website)... nothing seems to work.  Any suggestions for what to try next would be more than welcome!
It's definitely not an account issue, as I just confirmed that scrobbling works fine.
