Full Version: reading tagged music files problem and no music library created Libreelec
Hi since some time I'm struggling with creating a music library.
My media source is external hdd
I have installed LibrELEC on pi3B
I've tagged my files with musicbrainz picard
I think I did correctly all steps described in wiki
still no result...
this is my log:
https://paste.kodi.tv/udedumakan.kodi
if someone could take a look I'd be gratefull... It seems like its all tag reading problem...
Maybe someone could shaer exaplery music files that are tagged correctly so I could check if this is tagging issue or sth else..
Regards
and sorry for all spelling mistakes as english is not my native..
@skaua
It looks like your music files are not tagged according to this extract from your log...
xml:
ScanTags - No tag found for: /media/Seagate Backup Plus/muzykatg/Bebel Gilberto/Tanto tempo/02 August Day Song.wav
Did you save the tags when you ran MusicBrainz Picard? Saving is not automatic, you have to press Save, usually when you have highlighted the album, or on every song if you choose to save individually.
==Edit==
Just noticed it is a WAV file. You cannot save tags in a wav file. Convert your files to FLAC
WAV files can be tagged, however Picard does not support writing of tags to a WAV files see https://community.metabrainz.org/t/music...les/185024
Seems mp3tag supports WAV tags and is a popular tag editor, see https://www.leawo.org/tutorial/edit-wav-tags-1387.html
