Full Version: PVR IPTV Simple Client v3.8.8.1 - where is favorites channels???
Hello,
I'm currently using:
LibreELEC 9.2.0
Kodi 18.5
I'm able to load my m3u IPTV list without any issue. Also I'm able to favorite a lot of channels.
But how can I see the list of only favorite channels? I would like to see only the favorites channels.
Thanks,
Marlon
I think you need to go to favourites on the main menu.
(2020-01-07, 03:09)phunkyfish Wrote: [ -> ]I think you need to go to favourites on the main menu.
Sorry, but I'm unable to find this option yet. Are you able to provide the step-by-step?
If you mean you have selected 'Add to Favourites' via context menu, they should appear under the 'Favourites' heading on the main Kodi home menu (depending what Skin you are using). Unfortunately, when you favourite a Live TV channel in Kodi it does not create a Favourites Channel Group as far as I know. If that's what you are looking for, you would need to do this yourself, by manually creating a favourites channel group on your current IPTV list.
