2020-01-07, 16:58
This is a small utility that aims to create an automatic process to use HDR with Jogal's (Thexai) fork of Kodi.
Auto HDR for Kodi on Windows 10 OS
This code was only possible by the help of DMU who provided the first draft and Thexai (Jogal) who fixed it's crashes.
INSTRUCTIONS:
!! This should be used ONLY with Thexai (Jogal's fork at the moment !! You can get it here:
https://github.com/thexai/xbmc/releases
FAQ:
1. What does this do?
This will turn HDR on before openning Kodi and turning it off when Kodi closes.
2. Why I need this?
You don't.
You can enable HDR from within Kodi (thanks to Jogal's work), just go into the upper left corner and turn HDR on from there.
or
You can enable HDR within Windows 10 display settings and open kodi and when you are done you can go into display settings again and turn it off.
3. How do I know it's working?
R: Open power settings on upper left corner and check if it says "Toggle HDR OFF". If it says to turn it OFF means it is ON.
4. I have started Kodi using AUTOHDR.bat but the KODI Graphic User Interface is not in HDR, why?
R: The user interface is not rendered in HDR, when you start a video file that has HDR metadata and your display is HDR capable it will switch your TV to HDR mode.
5. What about movies that are not HDR?
R: Movies that are not HDR, meaning that those do not have HDR metadata will be rendered in SDR as normal.
Source code:
https://github.com/fandangos/AutoHDR
Release:
https://github.com/fandangos/AutoHDR/releases
Enjoy
INSTRUCTIONS:
- Be sure that Windows HDR is OFF.
- If you Windows HDR settings is OFF, keep it off.
- Download AUTOHDR.exe from the release section. HERE: https://github.com/fandangos/AutoHDR/releases
- Add the file to your Kodi installation folder.
- Do NOT start Kodi.exe, start AUTOHDR.exe and it will launch Kodi for you.
FAQ:
2. Why I need this?
You don't.
or
Source code:
Release:
Enjoy
