hi all,
is it possible to create a video library without files.
i would like to create a database of tvseries i have seen along last years and now, i have not all files.?
is there any addon or can i download info from themoviedb.org and save it into any folder that kodi can use it?
(2020-01-07, 23:50)sunevil Wrote: [ -> ]is it possible to create a video library without files.
Not unless you have a certain amount of SQL expertise.
(2020-01-07, 23:50)sunevil Wrote: [ -> ]i have not all files?
You can create stub/placebo files for those episodes you do not have. Use a simple & small video file, and copy&rename it as often as necessary. Batch rename tools are handy for that.
(2020-01-07, 23:50)sunevil Wrote: [ -> ]is there any addon or can i download info from themoviedb.org and save it into any folder that kodi can use it?
Not that I'm aware of.
(2020-01-07, 23:57)Klojum Wrote: [ -> ] (2020-01-07, 23:50)sunevil Wrote: [ -> ]is it possible to create a video library without files.
Can you explain me more about this or can you give me a link?
(2020-01-07, 23:57)Klojum Wrote: [ -> ] (2020-01-07, 23:50)sunevil Wrote: [ -> ]i have not all files?
I think this is tedious for me now
(2020-01-07, 23:57)Klojum Wrote: [ -> ] (2020-01-07, 23:50)sunevil Wrote: [ -> ]is there any addon or can i download info from themoviedb.org and save it into any folder that kodi can use it?
Thank you for your response!
(2020-01-08, 01:22)sunevil Wrote: [ -> ] (2020-01-07, 23:57)Klojum Wrote: [ -> ] (2020-01-07, 23:50)sunevil Wrote: [ -> ]is it possible to create a video library without files.
Do you no if is it possible if i use themoviedb API to generate an nfo file like
https://kodi.wiki/view/NFO_files/TV_shows. could this file be interpreted by kodi and show it as video library
