Full Version: Not scrapping movie sometimes
why is not scrapping?
I think it was doing it before
https://paste.kodi.tv/egalolewak.kodi
From what I see, the first URL give me result in the browser, but the second does not. In either way, <results> is empty
2020-01-11 21:06:25.695 T:51480   DEBUG: CScraperUrl::Get: Using "UTF-8" charset for "https://api.tmdb.org/3/search/movie?api_key=f090bb54758cabf231fb605d3e3e0468&query=A%20Bread%20Factory%2c%20Part%20Two&year=2018&language=en"
2020-01-11 21:06:25.697 T:51480   DEBUG: scraper: GetSearchResults returned <results></results>
2020-01-11 21:06:25.720 T:51480   DEBUG: CScraperUrl::Get: Using "UTF-8" charset for "https://api.tmdb.org/3/search/movie?api_key=f090bb54758cabf231fb605d3e3e0468&query=A.Bread.Factory%2c.Part.Two&year=&language=en"
2020-01-11 21:06:25.721 T:51480   DEBUG: scraper: GetSearchResults returned <results></results>
Because you have named it wrong.
A.Bread.Factory..Part.Two.2018.1080p.AMZN.WEBRip.DDP2.0.x264-Cinefeel is how you have named it
A Bread Factory, Part Two Is what the scraper is searching for (see last comment)
A Bread Factory Part Two Walk with Me a While (2018) Should be named this way
Clean your filenaming and check TheMovieDB site to confirm you have named them correctly.
Also I think you have Item 1d enabled here which may cause you problems... https://forum.kodi.tv/showthread.php?tid=336969
(2020-01-11, 22:55)Karellen Wrote: [ -> ]Because you have named it wrong.
Video tags were disabled, but this did not make a difference (enabled or disabled)
I name the file 'A Bread Factory Part Two Walk with Me a While (2018).mkv', but it's not scrapped either
From what I see in the logs, Kodi reads the name of the file, and then it tries to parse it different ways and uses this to search the movie in moviedb. Am I correct
If so,  it would seem that 'A%20Bread%20Factory%2c%20Part%20Two&year=2018&language=en' is one of those attempts, and would search for 'A Bread Factory Part Two', and this should be found. Why is it not?
I tried with an old install and I was able to scrap (GOOD). With the new one, I was not able to (BAD)
What is the difference?
GOOD:
https://paste.kodi.tv/oduruyevec.kodi
2020-01-12 17:54:17.440 T:48320   DEBUG: CScraperUrl::Get: Using "UTF-8" charset for "https://api.tmdb.org/3/search/movie?api_key=f090bb54758cabf231fb605d3e3e0468&query=A%20Bread%20Factory%20Part%20Two%20Walk%20with%20Me%20a%20While&year=2018&language=en"
2020-01-12 17:54:17.440 T:48320   DEBUG: scraper: GetSearchResults returned <results><entity><title>A Bread Factory Part Two: Walk with Me a While</title><id>549672</id><year>2018</year><url cache="tmdb-en-549672.json">https://api.tmdb.org/3/movie/549672?api_key=f090bb54758cabf231fb605d3e3e0468&amp;language=en</url></entity></results>
BAD:
https://paste.kodi.tv/quhimirosu.kodi
2020-01-12 17:52:52.481 T:24392   DEBUG: CScraperUrl::Get: Using "UTF-8" charset for "https://api.tmdb.org/3/search/movie?api_key=f090bb54758cabf231fb605d3e3e0468&query=A%20Bread%20Factory%20Part%20Two%20Walk%20with%20Me%20a%20While&year=2018&language=en"
2020-01-12 17:52:52.483 T:24392   DEBUG: scraper: GetSearchResults returned <results></results>
