Hi All,
First post here. So I have just installed Tiny Media Manager and trying to learn the interface etc. I have just tried scrapping my first video file, but I noticed that all the metadata has been added as separate files. So I have the video file, a bunch of JPG and the .nfo file. Is there a way to add this directly to the container of the video file, so for example if my video file was .mkv I could add it to there, rather than having all these separate files. ?
If the answer is no, then all my video files are in one great big folder, so I would need separate sub folders for each movie. Is there a quick way to do this?
Thank you
Take a look at
Media-Buddy. I think it does what you are asking for.
I am not sure if Kodi will read that data though.
(2020-01-12, 16:44)mcoliver88 Wrote: [ -> ]Hi All,
Thank you
There is very limited functionality with embedded metadata, if you are using Kodi. Have a look here for more information
https://kodi.wiki/view/Video_file_tagging
File2Folder can help you create and move your video files into individual folders.
Guide:
https://www.howtogeek.com/howto/19707/qu...d-folders/
Download Link:
https://code.google.com/archive/p/file2f.../downloads
No, TMM does not alter your video files at any cost, thus not adding metadata to .MKV
TMM has a renamer function, which creates one movie per folder as default.
Play around in the settings for various customisations....
Thank you
Just for you to know, I have 5000 movies into the same folder, all with their correspond .nfo & .jpg files, and I have no problem at all with Kodi, Infuse or Plex.
If you wan to move your movies to a specific folder for each movie, you can do it with TMM. Just put:
* In folder name: ${title} (${year})
* In File name: Leave it empty, so it doesn't rename the files
Anyway, as I said, it is not neccesary to move all your movies to specific folder for each movie.
Regards,
