Full Version: special character front slash causes an error
special character front slash causes an error:
java.nio.file.InvalidPathException: Trailing char < > at index 67: C:\Program Files\Kodi\portable_data\media\Movie Sets\Auf der Flucht / Jagd Filmreihe-poster.jpg
    at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
    at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
    at sun.nio.fs.WindowsPath.parse(Unknown Source)
    at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
    at java.nio.file.Paths.get(Unknown Source)
    at org.tinymediamanager.core.movie.MovieSetArtworkHelper.findArtworkInArtworkFolder(MovieSetArtworkHelper.java:389)
    at org.tinymediamanager.core.movie.MovieSetArtworkHelper.updateArtwork(MovieSetArtworkHelper.java:78)
    at org.tinymediamanager.core.movie.entities.MovieSet.removeAllMovies(MovieSet.java:347)
    at org.tinymediamanager.ui.moviesets.dialogs.MovieSetChooserDialog.actionPerformed(MovieSetChooserDialog.java:380)
    at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
    at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
    at com.jtattoo.plaf.BaseButtonListener.mouseReleased(BaseButtonListener.java:66)
    at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
    at java.awt.Component.processMouseEvent(Unknown Source)
    at javax.swing.JComponent.processMouseEvent(Unknown Source)
    at java.awt.Component.processEvent(Unknown Source)
    at java.awt.Container.processEvent(Unknown Source)
    at java.awt.Component.dispatchEventImpl(Unknown Source)
    at java.awt.Container.dispatchEventImpl(Unknown Source)
    at java.awt.Component.dispatchEvent(Unknown Source)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
    at java.awt.Window.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.access$500(Unknown Source)
    at java.awt.EventQueue$3.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
    at java.awt.EventQueue$4.run(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.WaitDispatchSupport$2.run(Unknown Source)
    at java.awt.WaitDispatchSupport$4.run(Unknown Source)
    at java.awt.WaitDispatchSupport.enter(Unknown Source)
    at java.awt.Dialog.show(Unknown Source)
    at java.awt.Component.show(Unknown Source)
    at java.awt.Component.setVisible(Unknown Source)
    at java.awt.Window.setVisible(Unknown Source)
    at java.awt.Dialog.setVisible(Unknown Source)
    at org.tinymediamanager.ui.dialogs.TmmDialog.setVisible(TmmDialog.java:239)
    at org.tinymediamanager.ui.moviesets.dialogs.MovieSetChooserDialog.showDialog(MovieSetChooserDialog.java:469)
    at org.tinymediamanager.ui.moviesets.actions.MovieSetSearchAction.processAction(MovieSetSearchAction.java:61)
    at org.tinymediamanager.ui.actions.TmmAction.actionPerformed(TmmAction.java:35)
    at javax.swing.AbstractButton.doClick(Unknown Source)
    at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
    at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
https://www.themoviedb.org/collection/13...uage=de-DE
can you maybe hotfix it or tell us what needs to be changed?
Thanks and best regards,
Seger
Can we also have the full Kodi debug log (wiki) please, just to know what the other puzzle pieces look like?
Preferably via a pastebin website (AKA not splattered onto the forum like the java listing was).
Never mind... I overlooked the fact that this is the TMM section.
That doesn't happen a lot, just sometimes... Big Grin
(2020-01-13, 00:12)Klojum Wrote: [ -> ]Can we also have the full Kodi debug log (wiki) please, just to know what the other puzzle pieces look like?
Attached:
LOG
https://transfernow.net/94ewe1f6pbi9
Well, java seems to treat this "special" character as normal path delimiter.
And thus it complains about having a " " space around it.
Since removing the space does not solve this, you might want to remove such specialities and jus use parenthesis or similar.
PS:
How did you create this file?
Via TMM?
So we did not replace this special character?
(What ASCII code is this?)
should be fixed in the next release
