Hey everyone I'm having a issue with my movie files.
The issue is that when I add the movie folder & scrap it, it actually shows it actually scrapping or go through the movie folder to get the info about movie but then i go into the movie folder it shows no movie files in there.
Could please someone tell me what I'm doing wrong
We can't tell you what is going wrong without additional information. Sounds like Kodi cannot find the movie, most likely due to a naming problem. Provide a
Debug Log which captures the scraping of the movie.
(2020-01-13, 20:30)Karellen Wrote: [ -> ]We can't tell you what is going wrong without additional information. Sounds like Kodi cannot find the movie, most likely due to a naming problem. Provide a Debug Log which captures the scraping of the movie.
I'm all new to this, how do provide a debug log?
jbourne86
Perfect.
From what I can see, most of your movies have been scraped into the library. There are some that were missed because of bad naming. Some examples...
1999 The Matrix
2003 The Matrix Reloaded
2003 The Matrix Revolutions
In the above case, you have placed the Year at the start, which won't work as Kodi thinks that is the name of the movie.
Gemini Men
The Kithcen
Wrong name due spelling mistakes
Bring down the house - No such movie exists.
If you fix the naming, the movies should appear in the library.
Use the
Event log (wiki) to find movies that were missed.
So you pretty much saying the year of the movie that it was made should before the movie title ?
The:
1999 The Matrix
Should be:
The Matrix (1999)
The Matrix Reloaded (2003)
The Matrix Revolutions (2003)
(2020-01-14, 10:51)DarrenHill Wrote: [ -> ]The:
1999 The Matrix
Should be:
The Matrix (1999)
here a more recent log it just did
I hope this help a bit more
https://paste.kodi.tv/ucugemufeg
We don't need anymore logs, thanks. The very first one you provided was perfect.
Both Darren and I have told you what the problem is.
I tried what you both said the movie files are still not showing up
Here another log I jut did after doing what you said (putting the year after the movie name)
https://paste.kodi.tv/xitenokehu
It does not look like you changed anything as it is still exactly the same...
xml:
WARNING: No information found for item 'nfs://192.168.0.195/nfs/Public/Movies/Action/1999.The.Matrix.1920x796.BDRip.x264.TrueHD.mkv', it won't be added to the library.
WARNING: No information found for item 'nfs://192.168.0.195/nfs/Public/Movies/Action/2003.The.Matrix.Reloaded.1920x798.BDRip.x264.TrueHD.mkv', it won't be added to the library.
WARNING: No information found for item 'nfs://192.168.0.195/nfs/Public/Movies/Action/2003.The.Matrix.Revolutions.1920x796.BDRip.x264.TrueHD.mkv', it won't be added to the library.
WARNING: No information found for item 'nfs://192.168.0.195/nfs/Public/Movies/Action/Gemini Men (2019(.mp4', it won't be added to the library.
Also, you did not enable Debug Mode, so there is nothing else to see in the log.
