Full Version: Sling
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
Awesome, thanks. I'll keep an eye out for an update of that.
My old FireTV is holding out, just annoying to have two devices and two remotes, but good to hear this is a problem that'll eventually be resolved.
(2020-11-18, 01:27)matthuisman Wrote: [ -> ]oh, the author merged my PR so it's fixed in the actual code now.
He hasn't released a new version, but until then you can just download the git code:
https://github.com/d21spike/plugin.video...master.zip
Thanks for the work and fixing a piece of the puzzle.
IA 2.4.5 builds for Kodi 18
Windows x86_64: https://f.mjh.nz/ia/2.4.5-windows-x86_64.zip
Linux ARMV7 (RPI): https://f.mjh.nz/ia/2.4.5.1-linux-armv7.zip
Linux x86_64: https://f.mjh.nz/ia/2.4.5.1-linux-x86_64.zip
Android AARCH64: https://f.mjh.nz/ia/2.4.5-android-aarch64.zip
Android ARMV7: https://f.mjh.nz/ia/2.4.5-android-armv7.zip
For Windows / Linux - simply install via zip in Kodi
(if linux, make sure to apt-get remove kodi-addon-inputstream-adaptive first)
For Android, you need to follow these instructions
1) install downloaded zip
2) restart kodi
3) uninstall inputstream adaptive
4) restart kodi
5) install downloaded zip
6) restart kodi
7) test
Remember to turn off updates for Inputstream Adaptive or it will update to 2.4.6 again
@MoreBloodWine - please ignore the above. it's not suitable for you. You have to keep waiting unfortunately.
Sounds like your also using banned add-ons which make you eligible for ZERO assistance around here.
Oh, and this isn't even my add-on (and neither is IA) Smile
I get 403 forbidden for the Linux x86-64 one
Is there something special I have to do to get the zip file? I've been trying to find this linux input stream adaptive zip for weeks now.
@micolithe
yes, it needed a Libreelec user-agent.
I've downloaded them all and re-uploaded to my server so works now
Can we please get confirmation that add-on works again with IA 2.4.5.
Also, is the issue present on Matrix?
(2020-11-19, 02:16)matthuisman Wrote: [ -> ]@micolithe
I can confirm that IA 2.4.5 works with this add-on just fine.
I tried just installing 2.4.5 and restarting last night on my Ubuntu setup and it didn't work. I suspect the 2.4.6 was still running so I'm going to uninstall - restart - reinstall and see if that works.
@lasers or some other user
able to please get me a full debug log of a a video working with 2.4.5
& then another debug log with same video not working with 2.4.6
this may help narrow down what is happening
(2020-11-19, 20:39)snoopyjoe Wrote: [ -> ]
OK so inputstream adaptive on regular linux distros (i run mint which is based on ubuntu) doesn't actually get installed the same way as it does on windows. Mine was installed via apt-get using the team xbmc ppa. I think that's why installing the zip through the plugin manager isn't working.
I'm having trouble viewing any content with this plugin.  When I open the plugin, it goes to the regular video files page where I can pick add videos, files, etc.  Here is a log that can hopefully tell you more.  Thanks. https://pastebin.com/CGSX7AYw .  I'll add that I am using IA 2.45
I got this addon working when I downgraded to IA 2.4.5 and rebooted. I then tried installing the latest nightly build of LibreELEC running Matrix, but this addon would not install because it requires Python 2. Where can I find a version of this addon that supports Matrix?
yes, that's because the bug hasn't been found yet and still present in Matrix version.
I don't have a Sling login so can't personally test so rely on users.
again, this is not my add-on - im just trying to help find the bug in Ia
Windows x86_64 Leia users, please try these builds.
Let me know which work and which don't.
01/11/2020 (09ec268dc43044051305a0f8f3b0bb3e2e2283d4):
https://f.mjh.nz/ia/01-11-09ec268dc43044...2283d4.zip
16/10/2020 (f7ce3a825ff7bfcc0534a7705b6c2629741de205)
https://f.mjh.nz/ia/16-10-f7ce3a825ff7bf...1de205.zip
14/10/2020 (2ce76ad2a764b9e8d8094bf1b01a359a3a3983e8)
https://f.mjh.nz/ia/14-10-2ce76ad2a764b9...3983e8.zip
15/06/2020 (adb26e9bf088b30008aa8cd63c0e5cf808db0e34)
https://f.mjh.nz/ia/15-06-adb26e9bf088b3...db0e34.zip
06/06/2020 (0009bba44508328916082fba4b6f427c5974ea67)
https://f.mjh.nz/ia/06-06-0009bba4450832...74ea67.zip
(2020-11-21, 23:56)Jachin99 Wrote: [ -> ]I'm having trouble viewing any content with this plugin.  When I open the plugin, it goes to the regular video files page where I can pick add videos, files, etc.  Here is a log that can hopefully tell you more.  Thanks. https://pastebin.com/CGSX7AYw .  I'll add that I am using IA 2.45
Same issue. Sling from git and IA 2.45
(2020-11-25, 22:30)matthuisman Wrote: [ -> ]yes, that's because the bug hasn't been found yet and still present in Matrix version.
I tested all of them and the only one that worked was 06/06/2020
Great. So bug was introduced between 06/06 and 15/06. I'll try narrow down to single commit
