(2020-02-08, 06:00)bds3151 Wrote: [ -> ] (2020-02-08, 05:20)d21spike Wrote: [ -> ] (2020-02-08, 05:04)bds3151 Wrote: [ -> ]Tried again - still not working. Log -https://paste.kodi.tv/kuqaxuhoya
Definitely getting a 403. Can you toggle "Enable Debugging [Log Errors]" via Sling add-on settings and try playing something, via guide is sufficient or whichever is easiest. Then provide me that log. I tried two separate devices, even the same channel "Food Network" all with no issues.
I did have debugging on on the last log and tried several channels. Now getting log file too large to upload.
Here is the log....https://paste.kodi.tv/abehahucoc
(2020-02-08, 06:18)bds3151 Wrote: [ -> ] (2020-02-08, 06:00)bds3151 Wrote: [ -> ] (2020-02-08, 05:20)d21spike Wrote: [ -> ]Definitely getting a 403. Can you toggle "Enable Debugging [Log Errors]" via Sling add-on settings and try playing something, via guide is sufficient or whichever is easiest. Then provide me that log. I tried two separate devices, even the same channel "Food Network" all with no issues.
I'm sorry but Sling debugging is turned off in that log. I need it to see what the add-on is submitting for licensing. The screenshot below shows it toggled "ON"
(2020-02-08, 06:53)bds3151 Wrote: [ -> ] (2020-02-08, 06:33)d21spike Wrote: [ -> ] (2020-02-08, 06:18)bds3151 Wrote: [ -> ]Here is the log....https://paste.kodi.tv/abehahucoc
Pretty interesting. It was on in the Settings screen. It seems like the add on is not recognizing the setting. I remember that I changed my subscribed channels effective today. I'm now getting errors on the Win10/Slingtv app. Let's drop this for now and I'll get back with you if I can't resolve it with Sling TV. Thanks for your help again.
Awesome work guys! Not sure if anyone has this issue but the "open guide on startup" setting doesn't keep the guide from displaying at startup. Also if the slinger service is disabled then so is IPTV. I usually just have one box/addon running and then all other devices pull the guide info from there.
bds3151 - As your log contains
banned addons (wiki) in violation of the
forum rules (wiki) which you accepted and agreed to abide by when you signed up here, no support is available whilst they are installed. Please see our
piracy policy (wiki) for details.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
d21spike - just FYI in terms of offering support.
(2020-02-08, 10:10)DarrenHill Wrote: [ -> ]@bds3151 - As your log contains banned addons (wiki) in violation of the forum rules (wiki) which you accepted and agreed to abide by when you signed up here, no support is available whilst they are installed. Please see our piracy policy (wiki) for details.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
@d21spike - just FYI in terms of offering support.
To be sure I don't have anything installed that's banned, I installed Kodi clean with only the Sling app . I'm still experiencing the issue of being unable to play any channel EXCEPT ABC News. As I mentioned before, I did have Sling TV change my channel lineup on the 7th and that is when I started experiencing these issues. Here is my new log with the "Log Errors" set on and a few failed channel attempts and one successful for ABC News. My Win10 Sling TV app is working fine.
https://paste.kodi.tv/irotezacuf
bds3151 - thank you, yes that log is clean and fine for support (for reference anything in the addon/repo list within a log posted to our paste site that shows in orange is a
banned addon (wiki)). So you can see from your previous log which are the items we would strongly recommend you remove.
(2020-02-08, 16:40)DarrenHill Wrote: [ -> ]@bds3151 - thank you, yes that log is clean and fine for support (for reference anything in the addon/repo list within a log posted to our paste site that shows in orange is a banned addon (wiki)). So you can see from your previous log which are the items we would strongly recommend you remove.
Ok weird. I just tried the Sling add on again and all channels work now. So no more issues. I did nothing on my end.
anyone have issues with incorrect epg data being pulled?
(2020-02-09, 22:05)markeymark Wrote: [ -> ]anyone have issues with incorrect epg data being pulled?
had some initially, I believe in settings > live tv/pvr > general "clear data" did the trick for me
(2020-02-10, 02:56)clones Wrote: [ -> ] (2020-02-09, 22:05)markeymark Wrote: [ -> ]anyone have issues with incorrect epg data being pulled?
My guess is it's related to channel order changing with Sling adding/removing channels and the pvr caching data in the database. This is just a guess at the moment though.
d21spike
Great Add-on! I really appreciate the hard work you've done.
I'm having an issue playing channels from the Orange Sling package through IPTV Simple. The Blue Sling channels play just fine. I was trying to play South Park on Comedy Central, but nothing happens.
Here's my log with the error:
https://pastebin.com/5uzSYsBz
Orange Channels play fine through the add-on.
Here's my log showing the same South Park episode playing successfully through the add-on:
https://pastebin.com/cQUJ29es
It looks like they have different URLs that they are trying to play:
ERROR with IPTV:
plugin://plugin.video.sling/?mode=play&url=http://cbd46b77.cdn.cms.movetv.com/cms/api/channels/29938328f60d447299ec48511a09ebab/schedule/now/playback_info.qvt
SUCCESS with the add-on:
plugin://plugin.video.sling/?mode=play&url=http://cbd46b77.cdn.cms.movetv.com/cms/api/channels/3844c0aee4df43849a938774ee504b4a/schedule/now/playback_info.qvt
(2020-02-10, 21:53)Doctor Eggs Wrote: [ -> ]@d21spike
Here's my log with the error: https://pastebin.com/5uzSYsBz
Here's my log showing the same South Park episode playing successfully through the add-on: https://pastebin.com/cQUJ29es
ERROR with IPTV:
I am going to go out on a limb here and say you have changed subscription packages recently. With this, the add-on constantly checks for subscription changes but the guide can become stale due to it's nature.
More specifically, the PVR is trying to play the channel 29938328f60d447299ec48511a09ebab aka COMEDY (Comedy Central).
This channel is available to the following subscriptions:
Sling Orange
Sling Orange and Sling Blue
You are indeed subscribed to Sling Orange and Blue but your subscription package only comes back with 7a0ff80be0c14f4da6b6cc510b9be57b aka COMEDY-M (Comedy Central).
Thus, when you try to play the channel above, it sees it's
not in your subscription package and refuses to license.
You can try to trigger Channel Update and Guide Update via Sling add-on settings. If that does not work, proceed one step further to clear cache in the PVR database via Kodi settings...
(exert from IPTV Simple github page)
Clear the EPG cache
Settings->PVR & Live TV->Guide->Clear cache
For it to take effect in the case of EPG relatd config and for channel related config will need to clear the full cache
Settings->PVR & Live TV->General->Clear cache
A Kodi restart may be necessary for full effect.
