2020-01-18, 06:03
I have a strange problem, I bought a new Andoid box :
https://www.ebay.com.au/itm/2019-MX10-An...ctupt=true
and installed Kodi 18.5 on it. All is working ok, I have all my files stores on Windows 10 PC, simply sharing one folder that has everything in it so I can stream it on the box.
I set up the source as windows SMB, path , username, password, all is ok ... I can browse the directory on the Kodi on the box and play files directly.
HOWEVER ...
when I click update library, it starts scanning and you can see its downloading data however, after short while, the Windows PC shuts down !
anyone experienced this before?
all connections are over LAN.
HOWEVER ...
