Full Version: In progress TV Shows aren't showing up ?
Hi all
my problem is that after doing a fresh install of Kodi 18.5 on my Xbox one i cant seem to get my in progress TV shows to display on the home screen and they wont even display in the In Progress folder
I'm using the Aura skin which comes in the ready to pick Kodi Skins, i have the same issue with the standard Kodi skin
I also have a huge amount of Movies and TV shows, Movies and TV shows are on different drives !!
In progress movies displays fine and always have
hopefully someone knows a fix to this
Thank you
All fixed no need for reply’s
cheers
Thread marked solved.
