2020-01-20, 01:11
2020-01-20, 01:11
2020-01-20, 02:00
Disable
Widgets at the top and bottom will be removed.
Skins Settings / Main menu items / Enable Category widgets
.Widgets at the top and bottom will be removed.
2020-01-20, 02:02
You can turn it off from the Estuary settings, but it turns the categories off for every section, not just TV shows.
If you don't want to modify XML files to turn that off, you could take a look at my Estuary mod (link in signature). It allows you to, among other things, turn that categories off per section. There are also options for a smaller categories option and the ability to reorder the main menu and the widgets in each section.
2020-01-21, 02:42
(2020-01-20, 02:00)Klojum Wrote: [ -> ]DisableSkins Settings / Main menu items / Enable Category widgets
Thank you - that did exactly what I was looking for!
2020-01-21, 05:38
Thread marked solved.
