2020-01-24, 15:42
I moved TMM to my local SSD to scan across the network to the NAS I have the videos on. Now it never finishes "Getting Media Info". Why would this be occuring?
(2020-01-24, 15:42)jglazer63 Wrote: [ -> ]I moved TMM to my local SSD to scan across the network to the NAS I have the videos on. Now it never finishes "Getting Media Info". Why would this be occuring?I think the way TMM gets the mediainfo is by downloading the file, and then using the local copy to identify the details. So scanning your NAS will download your complete selection.
(2020-01-25, 08:45)mlaggner Wrote: [ -> ]libmediainfo is an external lib (not java) so we're having issues on bug hunting with that..
are you sure it hangs or is just the progressbar not closed?
@triptolemeus libmediainfo seeks the files on every "seekable" file system, so there is no need to copy it over to the computer where tmm runs.
(2020-02-20, 16:41)mlaggner Wrote: [ -> ]just as I have explained on _your_ other thread - you need to have a good connection to your media to achieve a good speed for libmediainfo.
Nothing else can be done from our side
