Full Version: Move & resize a 'windowed' videoplayer (videowindow type control)
Question:
How do I move / resize videowindow type control?
I have a control  defined in an XML as follows:
python:
        <control type="videowindow" id="300">
            <description>video window</description>
            <posx>640</posx>
            <posy>0</posy>
            <width>1280</width>
            <height>540</height>
            <visible>True</visible>
        </control>
I can interact with it via the xbmc.Player() class, but I can't seem to alter the control directly.
example:  the following fails with - RuntimeError: Unknown control type for python
python:
self.vidPlayer  = self.getControl(300)
How do i alter a videowindow type control created via XML? (change size and position)
BONUS:
Is there anyway to set the stretch type for a windowed video window programatically?  e.g. set it to stretch_16x9 as part of sending a xbmc.Player().play() command (or just before /after)?
Did you ever figure this out? I have the same question and haven't found a good solution yet
