Hello,
Can someone help with script to delete Epg database. This is what I have so far, but its not deleting:
import xbmc, xbmcgui
import os, sys, urllib, datetime, time, shutil, re
EPGDB = xbmc.translatePath('special://home/userdata/Database/Epg12.db')
def delete_file(EPGDB):
if os.path.exists(EPGDB):
os.remove(EPGDB)
(2020-01-28, 03:32)james739 Wrote: [ -> ]Hello,
os.remove(EPGDB)
Any reason why you don't use the "Clear guidedata" option in Kodi's LiveTV section?
(2020-01-28, 03:55)Lunatixz Wrote: [ -> ] (2020-01-28, 03:32)james739 Wrote: [ -> ]Hello,
os.remove(EPGDB)
Thanks Man! I didn't know about that option
os.remove(EPGDB)
So, I tried that and Epg12.db is still in database folder. Can you give me pointers on how to do it via script?
(2020-01-28, 04:23)james739 Wrote: [ -> ] (2020-01-28, 03:55)Lunatixz Wrote: [ -> ] (2020-01-28, 03:32)james739 Wrote: [ -> ]Hello,
os.remove(EPGDB)
Using "reset/clear" removes DB entries and does not delete the file... Why would you need to manually delete the files? Kodi DB's are file locked while in use.
(2020-01-28, 18:25)Lunatixz Wrote: [ -> ] (2020-01-28, 04:23)james739 Wrote: [ -> ] (2020-01-28, 03:55)Lunatixz Wrote: [ -> ]Any reason why you don't use the "Clear guidedata" option in Kodi's LiveTV section?
How can I access "reset/clear" with a custom button?
