Full Version: Frame skipping or blinking during playback a 4k/60z map scrolling video
Frame skipping or blinking during playback a 4k/60z map scrolling video.
It occurs when playing by Kodi on Sony X9000E or Kodi on Xbox One X.
But I can play it smoothly with Video Player of Sony X900E and Infuse Player on Apple TV 4k.
Video file:
  ed2k://|file|Scroll-Map-4k-60hz.mkv|666400762|e5fdd065930ba638c05809c86101a066|h=57hkmijlcbmr26gfqljlv3zhyagrep64|/
Kodi Version:
  18.5
Device Combo 1:
 Kodi installed on Sony 75X9000E
Device Combo 2:
 Kodi installed on Xbox One  X with HDMI output to Sony 75X9000E.
File Meta Data:
$ ffmpeg -i Scroll-Map-4k-60hz.mkv
MEMC:
  Occurs when MEMC is enabled or disabled.
ffmpeg version 4.2.1 Copyright © 2000-2019 the FFmpeg developers
Input #0, matroska,webm, from 'Scroll-Map-4k-60hz.mkv':
  Metadata:
    encoder         : libebml v1.3.4 + libmatroska v1.4.5
    creation_time   : 2016-08-09T20:45:31.000000Z
  Duration: 00:01:18.13, start: 0.000000, bitrate: 68235 kb/s
    Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709), 3840x2160 [SAR 1:1 DAR 16:9], 59.94 fps, 59.94 tbr, 1k tbn, 59.94 tbc (default)
    Metadata:
      BPS             : 68081403
      BPS-eng         : 68081403
      DURATION        : 00:01:18.080000000
      DURATION-eng    : 00:01:18.080000000
      NUMBER_OF_FRAMES: 4674
      NUMBER_OF_FRAMES-eng: 4674
      NUMBER_OF_BYTES : 664474494
      NUMBER_OF_BYTES-eng: 664474494
      _STATISTICS_WRITING_APP: mkvmerge v9.3.1 ('Mask Machine') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v9.3.1 ('Mask Machine') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2016-08-09 20:45:31
      _STATISTICS_WRITING_DATE_UTC-eng: 2016-08-09 20:45:31
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
    Metadata:
      BPS             : 191916
      BPS-eng         : 191916
      DURATION        : 00:01:18.114000000
      DURATION-eng    : 00:01:18.114000000
      NUMBER_OF_FRAMES: 3660
      NUMBER_OF_FRAMES-eng: 3660
      NUMBER_OF_BYTES : 1873920
      NUMBER_OF_BYTES-eng: 1873920
