Full Version: Logitech S510 (R-RD8) Media Remote keymappings
I discovered that my old Logitech S510 Media Remote, a remote control can become useful with some minor changes (see [1]).
Still a lot of buttons don't work (about half of the buttons).
From debug, and the code that the Keyboard Editor add-on shows for key-presses I see that a number of keys show the same code/key-id.
E.g. key id="61952"
Is this a driver issue, and is this something that can be solved?
From verifying the Media Remote with Setpoint and uberOptions (http://uberoptions.net/) I know the buttons work all well.
KeyKey idDebugevtest codeevtest stringLeftover Capture Data
Open windowkey id="61952"
  • DEBUG: CLibInputKeyboard:: ProcessKey - using delay: 400ms repeat: 80ms
  • DEBUG: Thread Timer start, auto delete: false
  • DEBUG: Keyboard: scancode: 0x8b, sym: 0x0000, unicode: 0x0000, modifier: 0x0
  • DEBUG: GetActionCode: Trying Hardy keycode for 0xf200DEBUG: Previous line repeats 3 times.
  • DEBUG: HandleKey: 0 (0xf200, obc-61697) pressed, action is
  • DEBUG: Thread Timer 140354597619456 terminating
code 139KEY_MENU10040327100000
Select windowkey id="61952"
  • DEBUG: Keyboard: scancode: 0x9a, sym: 0x0000, unicode: 0x0000, modifier: 0x0
  • DEBUG: Thread Timer 139939967469312 terminating
code 154KEY_CYCLEWINDOWS1004032b100000
Close windowkey id="61952"
  • DEBUG: Keyboard: scancode: 0xce, sym: 0x0000, unicode: 0x0000, modifier: 0x0
code 206KEY_CLOSE10040323100000
Preset 1key id="61933"
  • DEBUG: Keyboard: scancode: 0x94, sym: 0x00b7, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: launch_app2_pc_icon (0xf0c1) pressed, action is ActivateWindow(Programs)
code 148KEY_PROG110040319100000
Preset 2key id="61952"
  • DEBUG: Keyboard: scancode: 0x95, sym: 0x0000, unicode: 0x0000, modifier: 0x0
  • DEBUG: Previous line repeats 3 times.
code 149KEY_PROG21004031a100000
Preset 3key id="61952"
  • DEBUG: Keyboard: scancode: 0xca, sym: 0x0000, unicode: 0x0000, modifier: 0x0
code 202KEY_PROG31004031b100000
Backkey id="61616"
  • DEBUG: Keyboard: scancode: 0x9e, sym: 0x00a6, unicode: 0x0000, modifier: 0x0
  • DEBUG: Thread Timer 139939975862016 terminating
  • DEBUG: HandleKey: browser_back (0xf0b0) pressed, action is Back
code 158KEY_BACK1004032a100000
OKkey id="16838669"
  • DEBUG: CLibInputKeyboard:: ProcessKey - using delay: 250ms repeat: 33ms
  • DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
  • DEBUG: HandleKey: return (0xf00d) pressed, action is Select
code 28 (event8)KEY_ENTER0000280000000000
Up<none>
  • DEBUG: CLibInputPointer:: ProcessAxis - scroll: up, event.button.x: 0, event.button.y: 25
  • DEBUG: ProcessMouse: trying mouse action up
10040501000000
Down<none>
  • DEBUG: CLibInputPointer:: ProcessAxis - scroll: down, event.button.x: 0, event.button.y: 25
  • DEBUG: ProcessMouse: trying mouse action down
100405ff000000
Rightkey id="61570"
  • DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: right (0xf083) pressed, action is Right
  • DEBUG: Thread Timer 139941841762048 terminating
code 106 (event8)KEY_RIGHT00004f0000000000
Leftkey id="61571"
  • DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: left (0xf082) pressed, action is Left
code 105 (event8)KEY_LEFT0000500000000000
Volum Upkey id="61625"
  • DEBUG: Keyboard: scancode: 0x73, sym: 0x00af, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: volume_up (0xf0b9) pressed, action is VolumeUp
  • DEBUG: ------ Window Init (DialogVolumeBar.xml) ------
  • DEBUG: Thread Timer 139940562200320 terminating
  • DEBUG: ------ Window Deinit (DialogVolumeBar.xml) ------
code 115KEY_VOLUMEUP100403e9000000
Volum Downkey id="61624"
  • DEBUG: Keyboard: scancode: 0x72, sym: 0x00ae, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: volume_down (0xf0b8) pressed, action is VolumeDown
code 114KEY_VOLUMEDOWN100403ea000000
Mutekey id="61623"
  • DEBUG: Keyboard: scancode: 0x71, sym: 0x00ad, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: volume_mute (0xf0b7) pressed, action is Mute
  • DEBUG: Thread Timer 139941845661440 terminating
code 113KEY_MUTE100403e2000000
Zoom +key id="16839168"
  • DEBUG: Previous line repeats 1 times.
  • DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
  • DEBUG: Keyboard: scancode: 0x00, sym: 0x0000, unicode: 0x0000, modifier: 0x0
code 419KEY_ZOOMOUT10040320100000
Zoom -key id="16839168"
code 418KEY_ZOOMIN1004031f100000
Rotatekey id="16839168"
code 371KEY_ANGLE10040328100000
Mediakey id="61635"
  • DEBUG: Keyboard: scancode: 0xe2, sym: 0x00b9, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: launch_media_center (0xf0c3) pressed, action is
code 226KEY_MEDIA10040318100000
Skip to the start or previous file/track/chapterkey id="61627"
  • DEBUG: Keyboard: scancode: 0xa5, sym: 0x00b1, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: prev_track (0xf0bb) pressed, action is SkipPrevious
code 165KEY_PREVIOUSSONG100403b6000000
Play/Pausekey id="16838845"
  • DEBUG: Keyboard: scancode: 0xa4, sym: 0x0155, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: play_pause (0xf0bd) pressed, action is PlayPause
code 164KEY_PLAYPAUSE100403cd000000
Skip to the end or next file/track/chapterkey id="61626"
  • DEBUG: Keyboard: scancode: 0xa3, sym: 0x00b0, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: next_track (0xf0ba) pressed, action is SkipNext
code 163KEY_NEXTSONG100403b5000000
Fast forwardkey id="61626"
code 163KEY_NEXTSONG1004030c100000
Stopkey id="61628"
  • DEBUG: Keyboard: scancode: 0xa6, sym: 0x00b2, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: stop (0xf0bc) pressed, action is Stop
code 166KEY_STOPCD100403b7000000
Rewindkey id="61627"
  • DEBUG: Thread Timer 139940001040128 terminating
code 165KEY_PREVIOUSSONG1004030b100000
Sleepkey id="61633"
  • DEBUG: Keyboard: scancode: 0x8e, sym: 0x0143, unicode: 0x0000, modifier: 0x0
  • DEBUG: HandleKey: sleep (0xf0df) pressed, action is ActivateWindow(ShutdownMenu)
  • DEBUG: Activating window ID: 10111
  • DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
code 142KEY_SLEEP
[1] ~/.kodi/userdata/keymaps/mouse.xml
<keymap>
  <global>
    <mouse>
      <wheeldown>down</wheeldown>
      <wheelup>up</wheelup>
    </mouse>
  </global>
</keymap>
