Full Version: Kodi not starting error.
Hello!
I'm using Ubuntu 18.04, with architecture ARM. I installed Kodi via
sudo apt install kodi:
. When I run in terminal:
sudo kodi:
I've this error
/usr/lib/arm-linux-gnueabihf/kodi/kodi.bin: error while loading shared libraries: libx264.so.152: cannot enable executable stack as shared object requires: Permission denied:
Sorry, the source button, is not showing text. Text is:
1. "sudo apt install kodi"
2. "kodi"
3. "usr/lib/arm-linux-gnueabihf/kodi/kodi.bin: error while loading shared libraries: libx264.so.152: cannot enable executable stack as shared object requires: Permission denied"
If you are using an ARM device. as in Raspberry Pi, then simply use Raspbian and install Kodi.
If not, more hardware details are welcome.
(2020-01-30, 15:55)Klojum Wrote: [ -> ]If you are using an ARM device. as in Raspberry Pi, then simply use Raspbian and install Kodi.
There is a problem. I'm running Ubuntu on Android via Termux app. Something like VirtualBox.
