(2020-02-02, 12:16)kambala Wrote: [ -> ]thanks! Now it's clear that it's a signing issue, not an app one.
application ID ng.Kodi looks a bit strange. Could you try one with 3 components? E.g. com.ng.Kodi
FYI, I upgrade my VMware and to Catalina 10.15 and xCode the latest version, ios app signer is the latest version.
Still same problem with 3 components. com.Andy.kk. Log below, FYI ng.Kodi had been working on 13.3 and below all the while.
I am not very familiar with Xcode and just follows the guide and so far before the update to iOS 13.3.1 it had been working.
{"app_name":"Kodi","timestamp":"2020-02-02 21:39:35.26 +0800","app_version":"","slice_uuid":"6ee2f29f-968e-36e0-9a8f-e8f6f8ab8b6d","adam_id":0,"build_version":"1.0","bundleID":"com.Andy.KK","share_with_app_devs":true,"is_first_party":false,"bug_type":"109","os_version":"iPhone OS 13.3.1 (17D50)","incident_id":"E69E155D-5EC7-4E52-AAF3-312DFC0CC7D5","name":"Kodi"}
Incident Identifier: E69E155D-5EC7-4E52-AAF3-312DFC0CC7D5
CrashReporter Key: 40109af83ce080d2002644835f50022b9852f1c2
Hardware Model: iPhone12,1
Process: Kodi [3505]
Path: /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Kodi
Identifier: com.Andy.KK
Version: 1.0
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.Andy.KK [1329]
Date/Time: 2020-02-02 21:39:35.1988 +0800
Launch Time: 2020-02-02 21:39:34.3786 +0800
OS Version: iPhone OS 13.3.1 (17D50)
Release Type: User
Baseband Version: 1.04.06
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Description: DYLD, Library not loaded: @executable_path/Frameworks/libbluray.2.dylib | Referenced from: /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Kodi | Reason: no suitable image found. Did find: | /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dylib: code signature invalid for '/private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dylib' | /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dylib: stat() failed with errno=1 | /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dylib: code signature invalid for '/private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dylib' | /private/var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Frameworks/libbluray.2.dy
Triggered by Thread: 0
Thread 0 Crashed:
0 dyld 0x000000010459f2ac 0x104550000 + 324268
1 dyld 0x00000001045a6914 0x104550000 + 354580
2 dyld 0x00000001045a6948 0x104550000 + 354632
3 dyld 0x00000001045a377c 0x104550000 + 341884
4 dyld 0x0000000104557288 0x104550000 + 29320
5 dyld 0x000000010455122c 0x104550000 + 4652
6 dyld 0x0000000104551038 0x104550000 + 4152
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000006 x1: 0x0000000000000005 x2: 0x000000016f822c40 x3: 0x00000000000000a0
x4: 0x000000016f822840 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x00000000000003a0
x8: 0x0000000000000020 x9: 0x0000000000000009 x10: 0x4137463737333145 x11: 0x646f4b2f45343132
x12: 0x72462f7070612e69 x13: 0x736b726f77656d61 x14: 0x72756c6262696c2f x15: 0x0079642e322e7961
x16: 0x0000000000000209 x17: 0x0000000104599860 x18: 0x0000000000000000 x19: 0x0000000000000000
x20: 0x000000016f822840 x21: 0x00000000000000a0 x22: 0x000000016f822c40 x23: 0x0000000000000005
x24: 0x0000000000000006 x25: 0x00000001045c0000 x26: 0x00000001045c0000 x27: 0x00000001045c0000
x28: 0x0000000104634000 fp: 0x000000016f822810 lr: 0x00000001045a6914
sp: 0x000000016f8227d0 pc: 0x000000010459f2ac cpsr: 0x00000000
esr: 0x56000080 Address size fault
Binary Images:
0x1005dc000 - 0x102c33fff Kodi arm64 <6ee2f29f968e36e09a8fe8f6f8ab8b6d> /var/containers/Bundle/Application/2F644DEB-B0D6-4C13-805A-E1377F7A214E/Kodi.app/Kodi
0x104550000 - 0x1045b7fff dyld arm64e <e008b93875933f57b94a747bc6c3beb5> /usr/lib/dyld
0x18f2ba000 - 0x18f637fff CoreFoundation arm64e <dc2c95c6b95439e886a25e0af8801e87> /System/Library/Frameworks/CoreFoundation.framework/CoreFoundation
0x18f69f000 - 0x18f96afff Foundation arm64e <7a7a96af79e43db1890442e61cae8999> /System/Library/Frameworks/Foundation.framework/Foundation
0x1907bc000 - 0x190c04fff CoreAudio arm64e <3f986cb2a41f3bf78245e3d097083f80> /System/Library/Frameworks/CoreAudio.framework/CoreAudio
0x192666000 - 0x1929c6fff CFNetwork arm64e <e94fb3fd49b5399497b4f12c844cbe7e> /System/Library/Frameworks/CFNetwork.framework/CFNetwork
0x195cf8000 - 0x195df9fff CoreMedia arm64e <89ad72de99123e85b361ad7cd6d823f0> /System/Library/Frameworks/CoreMedia.framework/CoreMedia
0x195e60000 - 0x1960b7fff QuartzCore arm64e <4da865ca7f363d7f952e05a9e5ed505d> /System/Library/Frameworks/QuartzCore.framework/QuartzCore
0x196276000 - 0x1967e9fff CoreGraphics arm64e <ec19539856b13b91b6996b20fde8cb80> /System/Library/Frameworks/CoreGraphics.framework/CoreGraphics
0x1996e0000 - 0x1998defff AVFoundation arm64e <bae1d0dcb9063af29651a0f35779be54> /System/Library/Frameworks/AVFoundation.framework/AVFoundation
0x19a6c1000 - 0x19a8effff AudioToolbox arm64e <8b3c3977613a35cd9e099c8d6ad2d5c2> /System/Library/Frameworks/AudioToolbox.framework/AudioToolbox
0x19b9da000 - 0x19bd9cfff MediaPlayer arm64e <2f98b7312eb33094bafbf495513c5459> /System/Library/Frameworks/MediaPlayer.framework/MediaPlayer
0x19c66c000 - 0x19c6a2fff CoreVideo arm64e <8425dd4299353b3ea645ce6b2506f1b1> /System/Library/Frameworks/CoreVideo.framework/CoreVideo
0x1a38ce000 - 0x1a398afff VideoToolbox arm64e <746b696a17a5345588763dfa3787b26c> /System/Library/Frameworks/VideoToolbox.framework/VideoToolbox
0x1b9857000 - 0x1b9857fff UIKit arm64e <96df300bc0b432658133434fe94c795d> /System/Library/Frameworks/UIKit.framework/UIKit
0x1c43bb000 - 0x1c44adfff libiconv.2.dylib arm64e <585d7b1ecfde3dbd8cfb65745e2e7ac8> /usr/lib/libiconv.2.dylib
EOF
