I compiled xbmc by source at an ARMv7 architecture with Ubuntu. But it runs very slowly.Here is some of the log:
22:48:24 T:1106833200 M:320245760 ERROR: CXRandR::Query - unable to open xrandr xml
22:48:24 T:1106833200 M:320245760 NOTICE: Setup SDL
22:48:25 T:1106833200 M:319348736 DEBUG: CKeyboardStat::Initialize - XKb symbols pc_us_inet(evdev)
22:48:25 T:1106833200 M:319348736 INFO: LIRC Initialize: connect failed: No such file or directory
22:48:25 T:1106833200 M:319348736 DEBUG: Failed to connect to LIRC. Retry in 10s.
22:48:25 T:1106833200 M:319348736 INFO: Drives are mapped
22:48:25 T:1106833200 M:319348736 NOTICE: load settings...
22:48:25 T:1106833200 M:319393792 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
22:48:26 T:1106833200 M:319066112 DEBUG: RefreshEGLContext Succeeded! Format:A0|R5|G6|B5|BPP16
22:48:26 T:1106833200 M:319066112 INFO: GLES: Maximum texture width: 2048
22:48:26 T:1106833200 M:319066112 DEBUG: SECTION:LoadDLL(special://xbmc/system/ImageLib-arm.so)
22:48:26 T:1106833200 M:319066112 DEBUG: Loading: /media/xbmc/xbmc-arm/system/ImageLib-arm.so
22:48:26 T:1106833200 M:317923328 DEBUG: EGL_EXTENSIONS: eglCreatePbufferFromClientBuffer EGL_KHR_image EGL_AMD_create_image
22:48:26 T:1106833200 M:317923328 NOTICE: GL_VENDOR = Advanced Micro Devices, Inc.
22:48:26 T:1106833200 M:317923328 NOTICE: GL_RENDERER = AMD Z430
22:48:26 T:1106833200 M:317923328 NOTICE: GL_VERSION = OpenGL ES 2.0
22:48:26 T:1106833200 M:317923328 NOTICE: GL_EXTENSIONS = GL_AMD_compressed_3DC_texture GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_AMD_tiled_rendering GL_EXT_texture_filter_anisotropic GL_EXT_
texture_type_2_10_10_10_REV GL_EXT_bgra GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mip
map GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_O
ES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_NV_fence
22:48:26 T:1106833200 M:317923328 DEBUG: Shader - Loading shader file guishader_frag.glsl
22:48:26 T:1106833200 M:317923328 DEBUG: Shader - Loading shader file guishader_vert.glsl
22:48:26 T:1106833200 M:317288448 DEBUG: GL: Vertex Shader compilation log:
22:48:26 T:1106833200 M:317288448 DEBUG: GL: Vertex Shader compiled successfully
22:48:26 T:1106833200 M:317923328 DEBUG: GL: Pixel Shader compilation log:
22:48:26 T:1106833200 M:317923328 DEBUG: GL: Fragment Shader compiled successfully
22:48:26 T:1106833200 M:317796352 DEBUG: GUI Shader - Initialise successful : 0xa9e8b8
22:48:26 T:1106833200 M:317796352 WARNING: EGL: Same window as before, refreshing context
22:48:26 T:1106833200 M:317796352 INFO: GLES: Maximum texture width: 2048
22:48:26 T:1106833200 M:317796352 INFO: load language info file: special://xbmc/language/English/langinfo.xml
22:48:27 T:1106833200 M:316399616 INFO: load language file
pecial://xbmc/language/English/strings.xml
22:48:27 T:1106833200 M:316399616 INFO: load keymapping
22:48:27 T:1106833200 M:316399616 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
22:48:27 T:1106833200 M:316399616 INFO: Loading special://xbmc/system/Lircmap.xml
22:48:27 T:1106833200 M:316399616 DEBUG: CButtonTranslator::Load - no userdata Lircmap.xml found, skipping
22:48:27 T:1106833200 M:316403712 INFO: Checking skin version of: Confluence
22:48:27 T:1106833200 M:316403712 INFO: Skin version is: 2.11 (2.110000)
22:48:27 T:1106833200 M:316403712 INFO: GUI format 1024x768 1024x768
22:48:27 T:1106833200 M:316399616 INFO: Skin version is: 2.11
22:48:27 T:1106833200 M:316399616 INFO: Loading skin includes from /media/xbmc/xbmc-arm/skin/Confluence/720p/includes.xml
22:48:27 T:1106833200 M:315777024 INFO: load fonts for skin...
22:48:27 T:1106833200 M:315777024 INFO: Loading fonts from special://xbmc/skin/Confluence/720p/Font.xml
22:48:27 T:1106833200 M:313618432 INFO: load new skin...
22:48:27 T:1106833200 M:313618432 INFO: Skin version is: 2.11 (2.110000)
22:48:27 T:1106833200 M:313618432 INFO: Loading skin file: Home.xml
22:48:28 T:1106833200 M:312987648 DEBUG: Load Home.xml: 160.15ms
22:48:28 T:1106833200 M:312987648 INFO: Loading user windows, path special://xbmc/skin/Confluence/720p
22:48:28 T:1106833200 M:312987648 INFO: Loading skin file: special://xbmc/skin/Confluence/720p/custom_SkinSetting_1111.xml
22:48:28 T:1106833200 M:312987648 DEBUG: Load Skin XML: 334.40ms
22:48:28 T:1106833200 M:312987648 INFO: initialize new skin...
22:48:28 T:1106833200 M:312987648 INFO: Loading skin file: Pointer.xml
22:48:28 T:1106833200 M:312987648 DEBUG: Load Pointer.xml: 5.76ms
22:48:28 T:1106833200 M:312987648 DEBUG: Alloc resources: 35.37ms (6.30 ms skin load)
22:48:28 T:1106833200 M:312905728 INFO: skin loaded...
22:48:28 T:1106833200 M:312922112 DEBUG: SECTION:LoadDLL(libcurl.so.4)
22:48:28 T:1106833200 M:312922112 DEBUG: Loading: libcurl.so.4
22:48:28 T:1106833200 M:312922112 DEBUG: Activating window ID: 12999
22:48:28 T:1106833200 M:312922112 DEBUG: Checking if window ID 12999 is locked.
22:48:28 T:1106833200 M:312922112 DEBUG: ------ Window Init (Startup.xml) ------
22:48:28 T:1106833200 M:312922112 INFO: Loading skin file: Startup.xml
22:48:28 T:1106833200 M:312922112 DEBUG: Load Startup.xml: 20.59ms
22:48:28 T:1106833200 M:312922112 DEBUG: Alloc resources: 21.15ms (21.14 ms skin load)
22:48:28 T:1106833200 M:312922112 INFO: removing tempfiles
22:48:28 T:1106833200 M:312922112 DEBUG: DBus: Creating message to org.freedesktop.ConsoleKit on /org/freedesktop/ConsoleKit/Manager with interface org.freedesktop.ConsoleKit.Manager and method CanStop
22:48:28 T:1106833200 M:312799232 NOTICE: initialize done
22:48:28 T:1106833200 M:312799232 NOTICE: Running the application...
22:48:28 T:1106833200 M:312799232 DEBUG: ExecuteXBMCAction : Translating SetFocus(10)
22:48:28 T:1106833200 M:312799232 DEBUG: ExecuteXBMCAction : To SetFocus(10)
22:48:28 T:1106833200 M:312799232 DEBUG: Process - no user autoexec.py (/home/ubuntu/.xbmc/scripts/autoexec.py) found, skipping
22:48:29 T:1179374544 M:311341056 DEBUG: Process - The source file to load is /media/xbmc/xbmc-arm/scripts/autoexec.py
22:48:29 T:1179374544 M:311341056 DEBUG: Process - Setting the Python path to /media/xbmc/xbmc-arm/scripts:/media/xbmc/xbmc-arm/system/python/python24.zip:/media/xbmc/xbmc-arm/system/python/lib/python2.4/:/media/xbmc/xbmc-arm/system/py
thon/lib/python2.4/plat-linux2:/media/xbmc/xbmc-arm/system/python/lib/python2.4/lib-tk:/media/xbmc/xbmc-arm/system/python/lib/python2.4/lib-dynload
22:48:29 T:1179374544 M:311341056 DEBUG: Process - Entering source directory /media/xbmc/xbmc-arm/scripts
22:48:29 T:1179374544 M:311341056 INFO: Scriptresult: Success
22:48:29 T:1196151760 M:311341056 DEBUG: thread start, auto delete: 0
22:48:29 T:1196151760 M:311341056 NOTICE: DS: Starting DBUS server in Run Application aka thread
22:48:29 T:1106833200 M:311341056 DEBUG: CLastfmScrobbler: Clearing session.
22:48:29 T:1106833200 M:311341056 DEBUG: CLibrefmScrobbler: Clearing session.
22:48:29 T:1204540368 M:311205888 DEBUG: thread start, auto delete: 1
22:48:29 T:1106833200 M:311840768 DEBUG: ExecuteXBMCAction : Translating ReplaceWindow(Home)
22:48:29 T:1106833200 M:311840768 DEBUG: ExecuteXBMCAction : To ReplaceWindow(Home)
22:48:29 T:1106833200 M:311840768 DEBUG: Activating window ID: 10000
22:48:29 T:1106833200 M:311840768 DEBUG: Checking if window ID 10000 is locked.
22:48:29 T:1106833200 M:311840768 DEBUG: ------ Window Deinit (Startup.xml) ------
22:48:29 T:1106833200 M:311840768 DEBUG: ------ Window Init (Home.xml) ------
22:48:29 T:1106833200 M:311713792 DEBUG: Alloc resources: 190.89ms (0.00 ms skin load)
22:48:29 T:1215697872 M:311709696 DEBUG: thread start, auto delete: 1
22:48:29 T:1215697872 M:311709696 INFO: WEATHER: Downloading weather
22:48:36 T:1204540368 M:289665024 DEBUG: DoWork - took 6885 ms to load special://skin/backgrounds/videos.jpg
22:48:36 T:1224086480 M:293986304 DEBUG: DoWork - took 6844 ms to load special://skin/backgrounds/videos.jpg
