2011-06-22, 12:59
awesome, so they have fixed the dev packages. Was a while since I last compiled, will revisit now as it was a major pita to reinstall every time you compiled
tarzan23 Wrote:I'm using the official git. I'll try to setup my server for cross compiling for the pandaboard, 8x X5570 > omap 4430.
@topfs2: first of all thank you for the great work you are doing. regarding hardware acceleration, is the gstreamer backend (https://github.com/topfs2/xbmc/commits/gstreamer) useable, and are you planning on hooking up gst-ducati/libdce and your xbmc gstreamer backend?
--enable-gles --disable-vdpau --disable-optical-drive --enable-ccache --enable-nfs
[email protected]:/usr/local/lib/xbmc$ gdb ./xbmc.bin
GNU gdb (Ubuntu/Linaro 7.2-1ubuntu11) 7.2
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "arm-linux-gnueabi".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /usr/local/lib/xbmc/xbmc.bin...done.
(gdb) run
Starting program: /usr/local/lib/xbmc/xbmc.bin
[Thread debugging using libthread_db enabled]
params.c:OpenConfFile() - Unable to open configuration file "/home/tarzan/.smb/smb.conf":
No such file or directory
[New Thread 0x4677b400 (LWP 3173)]
[Thread 0x4677b400 (LWP 3173) exited]
PVR:(Warning): InitContext: ignoring buffer type CBUF_TYPE_PDS_VERT_SECONDARY_PREGEN_BUFFER [777, /eglglue.c]
Program received signal SIGSEGV, Segmentation fault.
0x0037f4d2 in Matrix4Mul (this=0x20030010, matrix=0xbeffeca0)
at MatrixGLES.cpp:268
268 );
14:29:19 T:1332507648 M:405499904 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
14:29:19 T:1332507648 M:405499904 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
14:29:19 T:1332507648 M:405499904 ERROR: ADDON: Dll VDR VNSI Client - Client returned bad status (4) from Create and is not usable
14:29:19 T:1332507648 M:405499904 INFO: Called Add-on status handler for '4' of clientName:VDR VNSI Client, clientID:pvr.vdr.vnsi (same Thread=no)
14:29:19 T:1332507648 M:405499904 ERROR: PVR - LoadClients - can't initialise client 'VDR VNSI Client'
14:29:19 T:1458115584 M:405499904 DEBUG: Thread Addon Status: VDR VNSI Client start, auto delete: 1
christian667 Wrote:My main interest in using the XBMC on the pandaboard is to watch TV using the VNSI VDR plugin. The VDR runs like a charm, even watchable from other clients over wifi, but the fresh compiled pandaboard xbmc shows an uncloseable info dialog saying the plugin could not be loaded.
The log says:
Code:14:29:19 T:1332507648 M:405499904 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
Does anybody know what the bad status (4) means? Is it documented anywhere?
The same git clone works on a i386 machine
BTW native compiling needs 3h and 45 minutes
dandel Wrote:and as a quick note, the OpenGL ES libs are definately included with the root packages (I verified this by looking at the file, arm-buildroot-2010.05-2010-10-12-10.00--svn1957.tgz) the main note is that the build root source tree under 'buildroot-(Release)/package/opengl'
