2008-07-23, 19:54
I recently decided to update, and before checking here I did my usual SVN checkout, apt-get the dependencies in README.linux, and ./build.sh. I was getting compile errors, so I compiled on my own same problem, I tried
and it installed fine, but when I go to play an iso, it crashes. avi's are fine. So Ifigure it was a build problem, came here and saw that there was a stable deb package.
So I
added the repository to sources.list and
appears to install fine but still iso files crash the app, so I
but I can still launch xbmc and get the app to run??
and iso files still crash
I looked in my home directory and there is not an XBMC directory, I looked in /usr/share and no XBMC directory?
How do I completely uninstall xbmc, so I can install the stable version?
$ sudo make && make install
So I
rm -rf /home/me/XBMC
sudo apt-get update && sudo apt-get install xbmc
sudo apt-get remove xbmc
$ xbmc
