First thing, awesome program. Thank you.
I would like to request a feature for a future release. A wildcard exclusion for folder names. Such as if folder is named "Other" no matter where it resides, it will not be included while scraping.
I use Plex with my absolutely enormous movie library. I keep all the extra video files that come with blurays/dvds in a folder labeled "Other" to allow Plex to see them, but not count them as a main movie.
TMM can not tell the difference in the current version from what research I have done.
My library is way too big to go through and add a .tmmignore file to each "Other" folder, unless someone has a program that can do this automatically of course?
Hence a request to expand the exclude function.
THANK YOU FOR ALL THE HARD WORK!
You can definitely run a command on a linux based NAS or similar to find all dirs named Other, and put a tmmignore file inside if it doesn't exist.
I would be certain you can do the same in powershell on windows.
(2020-02-05, 20:46)o1dscratch Wrote: [ -> ]First thing, awesome program. Thank you.
This will do it in windows powershell 3
javascript:
$wantToWriteFiles = 0; ## change to 1 to write the files out
$dirNameToStartIn = 'C:\Users\Dave\Test'
$DirNameToMatch = 'Extras'
$FileToWrite = '.tmmignore'
$filesArray = Get-ChildItem -Path ${dirNameToStartIn} -recurse |
where {$_.psiscontainer -AND $_.name -match ${DirNameToMatch}} |
select -expand fullname
$m = $filesArray |measure
$num = $m.Count
Write-Host "There are ${num} Folders that match ${DirNameToMatch}"
Foreach ($dir in $filesArray){
Write-Host "one such folder is ${dir}"
If ($wantToWriteFiles){
New-Item -Force -Path "${dir}\${FileToWrite}" -ItemType File
(2020-02-05, 21:39)wcndave Wrote: [ -> ] (2020-02-05, 20:46)o1dscratch Wrote: [ -> ]First thing, awesome program. Thank you.
javascript:
$num = $m.Count
Wow thanks! I have never used powershell before. Will have to give it a go later.
