I'm getting screen tearing while playing back h264 1080p files on N4000 gemini lake cpu in Ubuntu Mate.
I tried with Windows 10 but no screen tearing.
https://paste.kodi.tv/dubolaraqa
I don't see what difference Mate makes. What drivers are you using?
Turn of your Composite Manager if one is one. Also check you are using the correct video driver. A proprietary one will give you better performance than the open source ones in most cases
(2020-02-10, 02:36)gary9872 Wrote: [ -> ]Turn of your Composite Manager if one is one. Also check you are using the correct video driver. A proprietary one will give you better performance than the open source ones in most cases
I will try changing the video driver. Thanks for your suggestion.
Maybe you have the same problems as i had, Here is the solution i found in an other thread here:
Intel tearing problem
