I am running Libreelec 9.2.0 on a Raspberry 4, connected via HDMI to an amplifier.
Kodi works but it crashes every day while being idle.
Here is the crashlog:
http://ix.io/2aVm
We are also trying to hunt this down in the Libreelec forum (
https://forum.libreelec.tv/thread/21288-...tID=134355) but to me it looks like a Kodi issue.
If I am not mistaken it tries to give an output via HDMI which fails as obviously there is not output.
Same setup here, same issue. I have to reboot the raspberry pi 4 minimum every 24 hours as the crash impedes PVR recording. Will check for the log.
Just as a reference: I have migrated to a bundled Odroid N2/Coreelec setup and it runs without problems. So the crash is somewhere related to the Raspi 4.
(2020-02-10, 12:02)MrMister76 Wrote: [ -> ]Just as a reference: I have migrated to a bundled Odroid N2/Coreelec setup and it runs without problems. So the crash is somewhere related to the Raspi 4.
Unfortunately I have to correct myself as it just crashed. And through cross referencing I am meanwhile pretty sure it is related to backend updates from tvheadend.
http://ix.io/2blL
I've had a similar problem and I know of one other person having it too.
But just to confirm it's the same thing... Does the crash only occur when you've left a PVR/TV item selected? In other words, if you move the cursor to Kodi's Movies or Music menu, does the crash not occur?
Good question, let me verify this.
I have a hunch. Can you post the contents of your config.txt?
(2020-02-11, 01:01)speedwell68 Wrote: [ -> ]I have a hunch. Can you post the contents of your config.txt?
As I switched to Coreelec I don't think there is a config.txt anymore. Anything specific I should be looking for?
(2020-02-11, 08:27)MrMister76 Wrote: [ -> ] (2020-02-11, 01:01)speedwell68 Wrote: [ -> ]I have a hunch. Can you post the contents of your config.txt?
No idea about CoreELEC.
(2020-02-10, 23:37)doug Wrote: [ -> ]I've had a similar problem and I know of one other person having it too.
That is indeed related. I get the impression it is related to PVR refreshing, for example because the tv guide is updated.
doug Unfortunately I have to revert my statement. It just crashed again this night and just the movie section was selected.
Crash:
http://ix.io/2bLJ
speedwell68 which config part should I be looking at? Coreelec is configured a bit differently but still I can check
Milhouse anything I can do to help track down this crash?
