2020-02-11, 05:59
Is anyone having issues running Kodi 17x and 18x on the new Shield? the only thing i found working good is SPMC 16x on the shield but they run great on my firetv box .
(2020-02-11, 17:23)Hitcher Wrote: [ -> ]Nope, see here - NVIDIA Shield TV Pro (2019 new model)Why do you think i am having an issue play video files from my network drives with the shield that i never had with my Firetv box .
(2020-02-13, 00:35)markoco Wrote: [ -> ]Why do you think i am having an issue play video files from my network drives with the shield that i never had with my Firetv box .
(2020-02-13, 08:04)Hitcher Wrote: [ -> ]To receive meaningful assistance you will need to provide a full debug log.the log file can be found here https://paste.kodi.tv/yibovapihu
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2020-02-11, 17:23)Hitcher Wrote: [ -> ]Nope, see here - NVIDIA Shield TV Pro (2019 new model)Kodi Log is here https://paste.kodi.tv/yibovapihu
