Full Version: Apple TV. Impossible to install addons.
I have Kodi installed on my Apple TV 4, but I can't install any add-on. Every time I try to install any add-on, I have the log error: "check the log for more information".
I have tried to reinstall Kodi, I have even restored my apple tv to factory settings.... and every time I obtain the same error.
PS. I have enabled the  "Unknown Source" option and I have tried with different repositories.
can anybody help me? thanks!
(2020-02-13, 18:49)Fer23 Wrote: [ -> ]Every time I try to install any add-on, I have the log error: "check the log for more information".
You are not telling us much here. What are the add-ons? Are they from the Kodi repository, if not which repository?
In any case, more info is needed:
Please turn on debugging mode and try to catch the failure in the log.
Follow the procedure linked here debug log (wiki).
And as written in red below Do not post logs in the forum. Use https://paste.kodi.tv/ instead.
(2020-02-13, 19:03)OTinley Wrote: [ -> ]
Thank for your answer.
I have the same problem with all the Addons and all the repositories that I have try, even from the Kodi repository.
Here is my log file: qavapazole (paste)
2020-02-13 21:56:39.668 T:42271 NOTICE: CAddonMgr::FindAddons: repository.carnamaleon v3.5.1 installed
2020-02-13 21:56:39.668 T:42271 NOTICE: CAddonMgr::FindAddons: repository.jsergio v1.0.4 installed
Both repositories seem to contain other contents that can facilitate illegal video streams.
Support will be halted for now as per forum rules (wiki).
Where did you get these repository links?
(2020-02-13, 23:08)Fer23 Wrote: [ -> ]
The problem is with all the addons.  I have done a clean installation and again I have the same error.
Can anyone help me? I'm desperate, I don't know what else to try...
Here is my new log file: azofivifaf (paste)
Did you try using a stable build, you are currently using Kodi (19.0-ALPHA1 Git:20200213-1eff5afda0) which is very much a pre-release version.
(2020-02-14, 19:34)FXB78 Wrote: [ -> ]Did you try using a stable build, you are currently using Kodi (19.0-ALPHA1 Git:20200213-1eff5afda0) which is very much a pre-release version.
I'm going to try it, thank you! Do you know where can I download the last stable build for Apple TV? I only can found nightlies versions for tvOS... Thank you!
(2020-02-14, 23:50)Fer23 Wrote: [ -> ]
I have installed the oldest version that I have found on the web. It's kodi-20200203-99975be0-PR17312-merge-tvos.deb but it's an alpha version too. I can't found any oldest version. Can anyone help me, please?
PS. The result with this version is the same again: ecivakuxuz (paste)
I'm desperate, I don't know what else to do or where can I found any solution...
I know next to nothing about Apple devices but looking at the wiki here https://kodi.wiki/view/HOW-TO:Install_Ko...HD_and_4K) it sees there are no stable builds for this platform, only nightlies.
After looking at all the steps you need to take just to get it working I'd probably just buy something like a Firestick and use that instead Smile
