2020-02-13, 22:43
edlgenrator
https://github.com/Dnkhatri/edlgen
Generate edl files with timings for intro and outro for kodi with manual input
This is just a command line python script to generate edl files when you know how long the intro and outro are in a series It can be run by from terminal and will take as input file seconds(To skip for intro) seconds(To skip for Outro).
example
example
or this for all mp4 files in a directoryhtml:edlgen.py "inputfile" 30 70 > outputfile.edl
The script will read the total runtime of the video file and generate an edl as below with the 2608.48 being the total runtime of the videohtml:for i in .mp4; do edlgen.py "$i" 30 70 >"${i%.}.edl"; done
Currently I am using option 3 for Commercial Break as stable version of kodi does not support intro and outro yet. Once it does will change accordinglyhtml:
0.0 30.0 3
2538.48 2608.48 3
html:
0 - Cut
1 - Mute
2 - Scene Marker
3 - Commercial Break
4 - Intro
5 - Outro
