(2021-09-03, 10:34)Karellen Wrote: [ -> ] (2021-09-03, 10:29)blizzardreign Wrote: [ -> ]Any plans on doing it for the latest season that just released?
Sure. I haven't looked at it yet and I don't know how much info is out there.
Does this new season have a different order again? Or has Netflix learnt their lesson and sticking with a single episode order?
Well this time I believe it is Netflix that is the main studio, so they are going with part 5 as the latest season, with 5 episodes released now and 5 episodes in Dec.
(2021-09-03, 11:33)blizzardreign Wrote: [ -> ]Is it possible to somehow get those, using the API?
Yes, certainly. Silly me for not checking the alternate episode orders before posting
Follow this guide for TMDB...
https://kodi.wiki/view/Naming_video_file...ode_Groups
You will note there is no guide for TVDB as currently there is no way to access those alternate orders. We are waiting to see how their new scraper works, which is hopefully being released sometime before 1 October.
So there is still no solution for the TVDB TVScraper to get the Netflix Aired
Does somebody already has the NFO for Season 5 ?
(2021-09-04, 16:28)Zurg Wrote: [ -> ]NFO with all 5 parts
https://drive.google.com/file/d/1Mur3hZM...sp=sharing
How does it work? Inside there's only a link to TMDB website.
Nevermind, it does work indeed, the problem was that I had 4 seasons already scraped with OP's NFOs and Kodi didn't want to scrape the new season due to that. Thanks!
(2021-09-04, 20:04)GhostCasper Wrote: [ -> ] (2021-09-04, 16:28)Zurg Wrote: [ -> ]NFO with all 5 parts
Ok, help an old man out here, please.
Does this tvshow.nfo require the TMDB scraper, or will it also work with the TVDB scraper?
Cheers
/H
It works you have to put the NFO inside tvshow folder and then scrap info with TMDB
(2021-09-04, 21:53)jack_pott Wrote: [ -> ] (2021-09-04, 20:04)GhostCasper Wrote: [ -> ] (2021-09-04, 16:28)Zurg Wrote: [ -> ]NFO with all 5 parts
Cheers
/H
Yeah it uses the TMDB scraper. Currently, the TVDB api doesn't allow for this. Refer to this for guidance:
Notice
NFO files for Part 5, episodes 1-5 are available for download from the first post in this thread.
Awesome
Thanks a lot.
Just remove the 0 Kb *.mkv files from season 5, I just lost all my downloads and re-downloaded again ...
Hi !
Is it possible to update french nfo files ?
Thank you !
