Full Version: Kore when SSL is enabled
I enabled SSL in Services/Control and generated/installed a self-signed certificate. When SSL is enabled, I'm not able to connect to the server using Kore, but I can when it's disabled. I'm also able to connect via HTTPS using my browser. I also tried installing the certificate via Android's settings. Is it just not compatible with SSL yet?
Thanks for your help!
Hey,
Depending on which Android version (6 and up) you are running Kore indeed does not support self-signed certificates yet. We need to explicitly add support for that.
More info here: https://developer.android.com/training/a...ity-config
