2020-02-15, 23:13
Over the years the Add-on forum has fallen out of step with the Kodi Repository. In an effort to realign the forum with the Kodi Repo the add-on forum and its sub-forums will be rearranged.
The following will occur:
1. 5 new subforums will be added and 2 will be renamed (see image below)
2. Many threads will be moved to their correct forum. With approx 17,000 threads in the forum, this will be a slower process. Currently active threads will be moved if they are in the wrong location, older or inactive threads will be moved when it is brought to our attention they are in the wrong location.
The correct forum will be determined by the Kodi Repo and in which category the add-on is listed. If your add-on is not in the Kodi Repo, then the correct forum is determined by the Extension Point of your add-on.
I know in the past there has been some concern about moving established threads, but in this instance if a thread is in the wrong sub-forum, it will be moved. This should only be a short term inconvenience for which we apologise.
If you have any questions, feel free to ask.
