Full Version: Update Library stuck on preparing
Was using ver 17.6 for a long time and recently switched to Leia, but the issue persists.
When I Update Library it is stuck on Preparing.
However if I go to my sources and Scan For New Content it updates my library immediately.
Any thoughts on this?
thank you
(2020-02-16, 15:24)homerjs Wrote: [ -> ]Was using ver 17.6 for a long time and recently switched to Leia, but the issue persists.
thank you
please ignore, I figured this out by checking debug logs.. delete post
Good nuff, I would like to inject the idea that the best form of back-up ant has persisted from almost the first versions of Kodi is the export to separate files function which puts all the meta-data beside each movie. Makes a fresh library re-scan quick and easy.
