Full Version: Where is this artwork coming from?
Pages: 1 2
...For album art, just let Artwork Beef in Kodi do it for you. It should download folder.jpg's and discart.png's to the album folders, direct from fanart.tv, and place all other artwork in a dedicated "Artist Information" folder to keep your music library clean from other (nessecary) clutter.
Alternatively, you can look into MusicBrainz Picard, but as I said above, it was designed for geeks (people like me), by geeks. So it's not the most user intuitive piece of software on the planet. It also requires an understanding of how it works to get the best out of it, and by that, I mean, it requires some changes from it's defaults to work well, settings-wise. But it absolutely will get your music tags straightened out (assuming the information exists). YMMV.
BTW: VLC Player is fine. While it's not "optimized" for music playback, it won't screw-up your artwork either.
Gib.
EDIT: Some final notes; If tagging your own music and including embedded art in the music files themselves, in addition to external (folder.jpg, discart.png) files, is don't embed folder.png files into tags. I'm pretty sure that's not supported by the MP3 spec for either ID3v2.3 and ID3v2.4 tags. It will cause issues on other devices / platforms you may use your music on, so avoid doing that. You'll also probably want to tag against the ID3v2.4 standard for maximum Kodi compatibility. Most tagging programs will do both standards, and the latter will be more compatible with Kodi moving forwards, and for other reasons I won't bore you with here.
(2020-02-16, 22:23)gibxxi Wrote: [ -> ]
(2020-02-16, 11:04)Jeffers24 Wrote: [ -> ]
(2020-02-16, 01:14)gibxxi Wrote: [ -> ]Removing "Multimedia Support / Features" (and hence WMP and the WMPNetworkService) from Windows via "Add/Remove Programs - Turn Windows Features On or Off" will also stop "Cast To..." functionality from working, which strangely doesn't seem to mess with album artwork, as far as i've experienced thus far (Still waiting for the other shoe to drop on this one).
Not sure if that other piece of garbage they coded (Groove Music Player) also exhibits the same "functionality" as WMP. Once bitten, twice shy. I don't use it. Get a decent music player:
Winamp: https://getwacup.com/ (Don't use the latest one from Winamp.com, as it's buggy as hell and the WASAPI plugin doesn't work properly).
Wink
Gib.
Windows is causing me a problem in that the album art it pulls in is not always correct, see example in pic below where all the album arts should be the same as the third one.
Given I can't see these album art files in windows how do I delete them?
They only show incorrectly on my windows laptop, on android following changes I made they are now showing correctly.
You'll need to open an explorer window (Windows Explorer) at the item location, and temporarily open up the advanced view settings dialog:
Ribbon Menu - > View -> Options (Far Right-hand-side)
In the dialog box that opens, select the "View" tab. Select the radio button for the option marked "Show Hidden files, folders and drives", you'll probably also need to uncheck the checkbox labelled "Hide protected operating system files (Recommended)" as Windows considers these clutter artwork files as "system files". It does the same for any Folder.jpg's with a leading upper case "F", but bizarrely ignores any files named folder.jpg (lower case "f"). For the second item, it will display a warning dialog box. As this is just a temporary change, just accept it and move on.
You can then click OK / Apply (or both) and the changes will be applied to all Windows Explorer instances. It is possible to hide / unhide files via the option in the ribbon menu too, but this won't affect system files, hence my reasoning behind showing you how to do both from the same dialog window. Once your done, you can (and probably should) reverse the above back to defaults.
You should then be able to see all the hidden clutter art in the album folder, and any other affected folder, as these changes are applied globally. Don't rule out the fact that the artwork may also be embedded into the actual music files too, so you might need to use a 3rd-party tool to remove/change that. I use "Tag&Rename" software for that, as it's superior in this regard to "MP3tag" IMHO. Or you could set up MusicBrainz Picard which also has a Fanart.tv plugin available where it can be configured to replace existing artwork embedded into music files, but Picard isn't for the faint of heart.
Hope this helps.
Gib.
Thanks, all the windows hidden sometimes incorrect clutter gone.
@pkscout  - Apologies for polluting your thread - Thanks for a great addon
@Jeffers24
Unpolluting the AS thread.
Pages: 1 2
