Full Version: [LINUX] Bug or Weird - all .py scripts crash after interaction
When I get some python scripts to run from my scripts folder, XBMC crashes after some interaction.
scripts/common scripts/listitemexample.py is the most notorius one, crashing concistently after two times enter or mouseclick or select.
This happens for all scripts that have their own window that I tried, making the powerfull scripting capabilities unusable.
Is this a bug in XBMC or a bug in my software (Ubuntu 8.04)? I don't know where to start looking for a solution.
I got the latest stable release from the hardy repository. I am no programmer so I do not have the unrecommended bleeding edge svn version for my own safety. Maybe someone can verify.
I *so* had to put "linux" in the subject bar, and I would if I could just edit my own post..
Maybe a mod can alter this?
No one on this?
I found out it's the 'activate' button that makes XBMC crash, either when used twice or when used once and then exiting the script, and when a xbmcgui.ControlList( is present.
A walkaround is to remove the def onControl section and use the def onAction section to recreate similar functionality using a button other then activate, for example use contect_menu in stead.
Somebody please comment on this as I'd like to know if there's a better walkaround that does not involve crippling scripts.
I thought I'd commented on this yesterday - weird.
In any case, please post a bug report on trac with all relevant information so that the developers can reproduce.
Thanks,
Jonathan
I allready did a few days ago http://trac.xbmc.org/ticket/4352
I got a single core reproducable error - no lockup but crash.
Since I'm a bugreport noob, can you tell me how to get backtrace? (A)
See the stickies, namely this one:
http://forum.xbmc.org/showthread.php?tid=34655
Cheers,
Jonathan
Ok, I hope this is done correctly, since the backtrace is very short.
http://trac.xbmc.org/ticket/4400
