2020-04-18, 19:17
(2020-04-17, 23:04)bacardicola Wrote: [ -> ]Just one line of rating, but kodi (18.6) does not see it as an imdb rating.Because it could be any rating (IMDB, TMDb, TVDb...).
(2020-04-18, 19:16)DanCooper Wrote: [ -> ]Thank you Dan.(2020-04-17, 19:22)ottix Wrote: [ -> ]I tried to change the language field under Settings -> Film -> Files and Sources, but unfortunately nothing changed.The source languge setting is only for new movies/tv shows. After changed the source language you also have to select all movies and tv shows in your list and set the language via context menu to that language you want.
(2020-04-19, 11:14)ottix Wrote: [ -> ]I tried deleting one film, deleting also all the files in the folder, renaming the avi file.(2020-04-18, 19:16)DanCooper Wrote: [ -> ]Thank you Dan.(2020-04-17, 19:22)ottix Wrote: [ -> ]I tried to change the language field under Settings -> Film -> Files and Sources, but unfortunately nothing changed.The source languge setting is only for new movies/tv shows. After changed the source language you also have to select all movies and tv shows in your list and set the language via context menu to that language you want.
I will immediately try as you say.
(2020-04-19, 13:04)Cromseth Wrote: [ -> ]The metadata load from video files (MKVs) just get one audio track, the "best" one (not always the first one). This way I can't see what movie is dubbed in my language or not until playing the real movie. The subs tracks are completely loaded, meanwhile. I don't see any option to change that or update mediainfo module. Is there something I can do to get all audio tracks?Ember reads always reads all streams and shows them as small language icon. As default the best audio stream will be displayed with a flag, but in Settings => Movies/TV Shows => General => Main Window => Show best audio ... you can enable that the best stream of a specific language should be displayed with a flag.
(2020-04-19, 13:04)Cromseth Wrote: [ -> ]Another problem I get its that with an EMM "default" configuration (without touching nothing at Kodi filenames template, using default) when I use Kodi interface to sync database I can update movie info, poster and fanart, but it seems that Kodi (I tried a few skins) dont load extra art as discart, clearart or clearlogo. Do I need to change any default option or value to achieve Kodi loads that extra art? I supossed that the default config would be the right one.The Kodi default skin does not support all of the additional image types. If you use the Kodi Interface to sync the images it not even important which file names you use because the Kodi Interface sends the image path and image type to the Kodi database, e.g.
poster=smb://SERVER/movies/Avatar/Avatar-poster.jpg
discart=smb://SERVER/movies/Avatar/Avatar-image-of-a-round-bluray.png
(2020-04-19, 13:04)Cromseth Wrote: [ -> ]For last, but just as curiosity, not real problem: When I enable "real time sync" in Kodi interface, each time I update a movie it tries and fails in the sync. If I sync "manually" via menu option it does it correctly. Is a bug in that option or its just me?Thats the the exact same function with the only difference that one is called automatically and the other manually. So it can't be a different result.
(2020-04-19, 11:40)ottix Wrote: [ -> ]Please check if the correct language for this movie is set (Context menu => Change Language, the correct language should already been pre-selected).(2020-04-19, 11:14)ottix Wrote: [ -> ]I tried deleting one film, deleting also all the files in the folder, renaming the avi file.(2020-04-18, 19:16)DanCooper Wrote: [ -> ]The source languge setting is only for new movies/tv shows. After changed the source language you also have to select all movies and tv shows in your list and set the language via context menu to that language you want.Thank you Dan.
Then I clicked on Update Library.
The system found the new file. I clicked on it and pressed CTRL+I
The file was correctly scraped but still in English![]()
Plot in English and Title in English.
(2020-04-19, 14:08)DanCooper Wrote: [ -> ]It should be as you says, but it only gets one (the "best") track of the MKV. It happens with all of my movies (all MKVs). I post some images to show it:(2020-04-19, 13:04)Cromseth Wrote: [ -> ]The metadata load from video files (MKVs) just get one audio track, the "best" one (not always the first one). This way I can't see what movie is dubbed in my language or not until playing the real movie. The subs tracks are completely loaded, meanwhile. I don't see any option to change that or update mediainfo module. Is there something I can do to get all audio tracks?Ember reads always reads all streams and shows them as small language icon. As default the best audio stream will be displayed with a flag, but in Settings => Movies/TV Shows => General => Main Window => Show best audio ... you can enable that the best stream of a specific language should be displayed with a flag.
(2020-04-19, 15:16)Cromseth Wrote: [ -> ]Image 3: Real Mediainfo from the file. It shows that the MKV has 3 audio tracks, not just one.
ffmpeg -ss 00:01:00 -i input.mp4 -to 00:02:00 -c copy output.mp4
(2020-04-19, 16:47)DanCooper Wrote: [ -> ](2020-04-19, 15:16)Cromseth Wrote: [ -> ]Image 3: Real Mediainfo from the file. It shows that the MKV has 3 audio tracks, not just one.
Ok, indeen that's strange/wrong. Can you send me a snipped of this video, e.g. created with ffmpeg?
Code:ffmpeg -ss 00:01:00 -i input.mp4 -to 00:02:00 -c copy output.mp4
-i: This specifies the input file. In that case, it is (input.mp4).
-ss: Used with -i, this seeks in the input file (input.mp4) to position.
00:01:00: This is the time your trimmed video will start with.
-to: This specifies duration from start (00:01:40) to end (00:02:12).
00:02:00: This is the time your trimmed video will end with.
-c copy: This is an option to trim via stream copy. (NB: Very fast)
The timing format is: hh:mms
(2020-04-19, 17:58)Boulder Wrote: [ -> ]Put quotes around the filename if there is a space in it.
(2020-04-19, 14:14)DanCooper Wrote: [ -> ]Thank you Dan.(2020-04-19, 11:40)ottix Wrote: [ -> ]Please check if the correct language for this movie is set (Context menu => Change Language, the correct language should already been pre-selected).(2020-04-19, 11:14)ottix Wrote: [ -> ]Thank you Dan.I tried deleting one film, deleting also all the files in the folder, renaming the avi file.
Please check that you've enabled a scraper that supports multi language (TMDb for movies, because IMDb is english only and all other scrapers are german only).
Please check that the TMDb scraper is on the top of the list.
Please check that your language is available for this movie on TMDb.
(2020-04-19, 14:08)DanCooper Wrote: [ -> ](2020-04-19, 13:04)Cromseth Wrote: [ -> ]Another problem I get its that with an EMM "default" configuration (without touching nothing at Kodi filenames template, using default) when I use Kodi interface to sync database I can update movie info, poster and fanart, but it seems that Kodi (I tried a few skins) dont load extra art as discart, clearart or clearlogo. Do I need to change any default option or value to achieve Kodi loads that extra art? I supossed that the default config would be the right one.The Kodi default skin does not support all of the additional image types. If you use the Kodi Interface to sync the images it not even important which file names you use because the Kodi Interface sends the image path and image type to the Kodi database, e.g.
So any file name works because Kodi don't have to search for an image with a file name that corresponds to a known file name scheme.Code:poster=smb://SERVER/movies/Avatar/Avatar-poster.jpg
You also can check if the sync has worked if you open the Information dialog on a movie in Kodi and select "Choose Art". In this list you should see all images and there type like:
As "default" file name Ember alsways use <stacked-filename>-imagetype.ext like Kodi whould do if you export your Kodi database to separate files. "imagetype" is the same "name" as Kodi uses in the column "type" in the table "art" (with the exception VIDEO_TS or BDMV folder structures and tv shows), e.g. "clearart", "clearlogo", "landscape" and so on.
(2020-04-19, 21:54)Cromseth Wrote: [ -> ]The skin meanwhile seems to download and use that art but I dont have "control" over that files (they are not obviously in movie folder).Settings looks ok. I thin MQ uses ArtworkBeaf or ArtworkDownoader to get the additional images. Both addons shoud have an option like "use local images instead of downloading them".
(2020-04-19, 22:48)DanCooper Wrote: [ -> ](2020-04-19, 21:54)Cromseth Wrote: [ -> ]The skin meanwhile seems to download and use that art but I dont have "control" over that files (they are not obviously in movie folder).Settings looks ok. I thin MQ uses ArtworkBeaf or ArtworkDownoader to get the additional images. Both addons shoud have an option like "use local images instead of downloading them".
