Full Version: Ember Media Manager 1.9.x - Download & Discussion Thread
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
(2021-05-24, 20:52)DanCooper Wrote: [ -> ]
(2021-05-24, 20:13)ralfonat Wrote: [ -> ]Or because updatetvshows after updatemovies resets new state?
Exactly! You have to run -updatemovies -scrapemovies newask all -updatetvshows -scrapetvshows newask all, that should work.
(2021-05-24, 20:13)ralfonat Wrote: [ -> ]Is this a parallel running problem?
No. The command line arguments will be processed one after the other.
ahh, makes sense! can i chain updastemoviesets in there?
THANK YOU
(2021-05-25, 20:09)ralfonat Wrote: [ -> ]
THANK YOU
-updatemovies -scrapemovies newask all -scrapemoviesets newauto all -updatetvshows -scrapetvshows newask all should work. The "new" flag will only be removed before a DB update and if you close Ember.
(2021-05-25, 23:21)DanCooper Wrote: [ -> ]
(2021-05-24, 20:52)DanCooper Wrote: [ -> ]Exactly! You have to run -updatemovies -scrapemovies newask all -updatetvshows -scrapetvshows newask all, that should work.
THANK YOU
Thanks a ton Dan. I will try it. Is this the recommended order for Kodi interface as well? Add movies first, then moviesets? Or other way around?
Also in EMM log I saw messages in the Kodi Interface like "ERROR: can't add, scrape in EMM first!", but this is probably the normal updatemovies call?
(2021-05-26, 19:28)ralfonat Wrote: [ -> ]Also in EMM log I saw messages in the Kodi Interface like "ERROR: can't add, scrape in EMM first!", but this is probably the normal updatemovies call?
That's only an information/trace log not an error and normal if a new movie whitout a NFO has been added to the DB.
(2021-05-26, 19:28)ralfonat Wrote: [ -> ]Thanks a ton Dan. I will try it. Is this the recommended order for Kodi interface as well? Add movies first, then moviesets? Or other way around?
Yes, movies first and than moviesets. So:
  1. update movie DB
  2. scrape new movies (new moviesets will be created)
  3. scrape new moviesets
  4. do other stuff
(2021-05-27, 01:27)DanCooper Wrote: [ -> ]
  1. update movie DB
  4. do other stuff
Awesome I will test. Thank you!
As for youtube trailer currently not working in release. Is it fixed on github and usable? Or should I wait?
(2021-05-29, 17:02)ralfonat Wrote: [ -> ]As for youtube trailer currently not working in release. Is it fixed on github and usable? Or should I wait?
It's fixed on GitHub but i whould wait. An officiall release is in the pipeline.
suddenly im getting a sync issue. new movies are not being added to kodi via sync. been a looooong time user and havnt had this issue before. it is able to update already scraped movies like 2 days ago but now its not working.
2021-06-10 21:09:54.6567,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Start] Movies Count [1],
2021-06-10 21:09:54.6567,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Start] Scraping Beyond Skyline (2017),
2021-06-10 21:09:54.6567,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Start] M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv,
2021-06-10 21:09:54.6723,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Using] TMDB_Data,
2021-06-10 21:09:54.6723,ScraperModule.TMDB_Data,ScraperModule.TMDB_Data.Scraper_Movie,6,TRACE,[TMDB_Data] [Scraper_Movie] [Start],
2021-06-10 21:09:54.8963,ScraperModule.Scraper,ScraperModule.Scraper.GetInfo_Movie,6,WARN,Unhandled certification language encountered: ru,
2021-06-10 21:09:55.2001,ScraperModule.TMDB_Data,ScraperModule.TMDB_Data.Scraper_Movie,6,TRACE,[TMDB_Data] [Scraper_Movie] [Done],
2021-06-10 21:09:55.2001,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Using] IMDB_Data,
2021-06-10 21:09:55.2001,ScraperModule.IMDB_Data,ScraperModule.IMDB_Data.Scraper_Movie,6,TRACE,[IMDB_Data] [Scraper_Movie] [Start],
2021-06-10 21:09:57.3155,ScraperModule.Scraper,ScraperModule.Scraper.GetMovieInfo,6,TRACE,"[IMDB] [GetMovieInfo] [ID:""tt1724970""] can't parse Tagline",
2021-06-10 21:09:57.7483,ScraperModule.IMDB_Data,ScraperModule.IMDB_Data.Scraper_Movie,6,TRACE,[IMDB_Data] [Scraper_Movie] [Done],
2021-06-10 21:09:57.7638,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Using] MoviepilotDE_Data,
2021-06-10 21:09:57.7638,ScraperModule.MoviepilotDE_Data,ScraperModule.MoviepilotDE_Data.Scraper_Movie,6,TRACE,[MoviepilotDE_Data] [Scraper_Movie] [Start],
2021-06-10 21:09:59.4922,ScraperModule.MoviepilotDE_Data,ScraperModule.MoviepilotDE_Data.Scraper_Movie,6,TRACE,[MoviepilotDE_Data] [Scraper_Movie] [Done],
2021-06-10 21:09:59.4922,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Using] OFDB_Data,
2021-06-10 21:09:59.4922,ScraperModule.OFDB_Data,ScraperModule.OFDB_Data.Scraper_Movie,6,TRACE,[OFDB_Data] [Scraper_Movie] [Start],
2021-06-10 21:10:02.1154,ScraperModule.OFDB_Data,ScraperModule.OFDB_Data.Scraper_Movie,6,TRACE,[OFDB_Data] [Scraper_Movie] [Done],
2021-06-10 21:10:02.1154,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Using] Trakttv_Data,
2021-06-10 21:10:02.1154,ScraperModule.Addon,ScraperModule.Addon.Scraper_Movie,6,TRACE,[Tracktv_Data] [Scraper_Movie] [Start],
2021-06-10 21:10:03.9276,ScraperModule.Addon,ScraperModule.Addon.Scraper_Movie,6,TRACE,[Tracktv_Data] [Scraper_Movie] [Done],
2021-06-10 21:10:03.9276,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeData_Movie,6,TRACE,[ModulesManager] [ScrapeData_Movie] [Done] M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv,
2021-06-10 21:10:04.1817,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeImage_Movie,6,TRACE,[ModulesManager] [ScrapeImage_Movie] [Start] M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv,
2021-06-10 21:10:04.1817,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeImage_Movie,6,TRACE,[ModulesManager] [ScrapeImage_Movie] [Using] FanartTV_Image,
2021-06-10 21:10:04.1817,ScraperModule.FanartTV_Image,ScraperModule.FanartTV_Image.Scraper_Movie,6,TRACE,[FanartTV_Image] [Scraper_Movie] [Start],
2021-06-10 21:10:04.4506,ScraperModule.FanartTV_Image,ScraperModule.FanartTV_Image.Scraper_Movie,6,TRACE,[FanartTV_Image] [Scraper_Movie] [Done],
2021-06-10 21:10:04.4506,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeImage_Movie,6,TRACE,[ModulesManager] [ScrapeImage_Movie] [Using] TMDB_Image,
2021-06-10 21:10:04.4506,ScraperModule.TMDB_Image,ScraperModule.TMDB_Image.Scraper_Movie,6,TRACE,[TMDB_Image] [Scraper_Movie] [Start],
2021-06-10 21:10:04.5728,ScraperModule.TMDB_Image,ScraperModule.TMDB_Image.Scraper_Movie,6,TRACE,[TMDB_Image] [Scraper_Movie] [Done],
2021-06-10 21:10:04.5889,EmberAPI.ModulesManager,EmberAPI.ModulesManager.ScrapeImage_Movie,6,TRACE,[ModulesManager] [ScrapeImage_Movie] [Done] M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv,
2021-06-10 21:10:49.8580,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Done] Scraping Beyond Skyline (2017),
2021-06-10 21:10:49.8580,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Done] Scraping,
2021-06-10 21:10:49.8960,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <BeforeEdit_Movie>,
2021-06-10 21:10:49.8960,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Kodi>,
2021-06-10 21:10:49.9273,generic.Interface.Kodi.KodiInterface,generic.Interface.Kodi.KodiInterface+VB$StateMachine_74_GenericRunCallBack.MoveNext,49,WARN,[KodiInterface] [GenericRunCallBack]: Please Scrape In Ember First!,
2021-06-10 21:10:49.9589,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Trakt.tv Manager>,
2021-06-10 21:10:50.0124,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <FrameExtrator_Movie>,
2021-06-10 21:10:50.0124,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Frame Extractor>,
2021-06-10 21:11:03.8784,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <ScraperSingle_Movie>,
2021-06-10 21:11:03.8784,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Renamer>,
2021-06-10 21:11:03.8784,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Kodi>,
2021-06-10 21:11:03.9316,generic.Interface.Kodi.KodiInterface,generic.Interface.Kodi.KodiInterface+VB$StateMachine_74_GenericRunCallBack.MoveNext,49,WARN,[KodiInterface] [GenericRunCallBack]: Please Scrape In Ember First!,
2021-06-10 21:11:03.9479,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Trakt.tv Manager>,
2021-06-10 21:11:03.9479,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <OnNFOSave_Movie>,
2021-06-10 21:11:03.9479,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,WARN,[ModulesManager] [RunGeneric] No generic modules defined <OnNFOSave_Movie>,
2021-06-10 21:11:09.1585,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <OnNFOSave_Movie>,
2021-06-10 21:11:09.1585,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,WARN,[ModulesManager] [RunGeneric] No generic modules defined <OnNFOSave_Movie>,
2021-06-10 21:11:09.3210,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <Sync_Movie>,
2021-06-10 21:11:09.3210,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Kodi>,
2021-06-10 21:11:09.3744,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_39_UpdateInfo_Movie.MoveNext,20,TRACE,"[APIKodi] [droopiePi3] UpdateInfo_Movie: ""Beyond Skyline"" | Start syncing process...",
2021-06-10 21:11:09.6598,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_SearchMovie.MoveNext,115,WARN,"[APIKodi] [droopiePi3] [SearchMovie] ""M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv"" | NOT found in host database!",
2021-06-10 21:11:09.6598,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_39_UpdateInfo_Movie.MoveNext,115,TRACE,"[APIKodi] [droopiePi3] UpdateMovieInfo: ""Beyond Skyline"" | NOT found in database, scan directory on host...",
2021-06-10 21:11:09.6598,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_48_VideoLibrary_ScanPath.MoveNext,115,TRACE,"[APIKodi] [droopiePi3] VideoLibrary_ScanPaths: ""nfs://server/mnt/user/Movies/Beyond.Skyline.2017/"" | Start scanning process...",
2021-06-10 21:11:09.7440,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_55_IsScanningVideo.MoveNext,115,TRACE,[APIKodi] [droopiePi3] IsScanningVideo: True,
2021-06-10 21:11:10.9486,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_55_IsScanningVideo.MoveNext,115,TRACE,[APIKodi] [droopiePi3] IsScanningVideo: False,
2021-06-10 21:11:12.6594,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_SearchMovie.MoveNext,115,WARN,"[APIKodi] [droopiePi3] [SearchMovie] ""M:\Beyond.Skyline.2017\Beyond.Skyline.2017.1080p.BluRay.x264-GUACAMOLE.mkv"" | NOT found in host database!",
2021-06-10 21:11:12.6594,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_39_UpdateInfo_Movie.MoveNext,115,ERROR,"[APIKodi] [droopiePi3] UpdateInfo_Movie: ""Beyond Skyline"" | NOT found on host! Abort!",
2021-06-10 21:11:12.6594,generic.Interface.Kodi.KodiInterface,generic.Interface.Kodi.KodiInterface+VB$StateMachine_74_GenericRunCallBack.MoveNext,1,WARN,[KodiInterface] [droopiePi3] [GenericRunCallBack] | Sync Failed:  Beyond Skyline,
2021-06-10 21:11:12.6594,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <Notification>,
2021-06-10 21:11:12.6594,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] Run generic module <Notifications>,
(2021-06-11, 04:16)dr-oopie Wrote: [ -> ]suddenly im getting a sync issue. new movies are not being added to kodi via sync. been a looooong time user and havnt had this issue before. it is able to update already scraped movies like 2 days ago but now its not working.
you have to enable the debug log in Kodi and check the log wo find out why Kodi does not add this movie.
closed
