(2020-02-24, 20:21)Cheadstina Wrote: [ -> ] (2020-02-23, 23:42)DanCooper Wrote: [ -> ] (2020-02-23, 23:26)Cheadstina Wrote: [ -> ]Sorry for the delay, here's the log: here
Looks like you don't have a proper installation because the IMDb trailer scraper and other already removed modules are still existing. Please reinstall the latest release over the existing one. Don't use the C:\Program Files folder because you've to edit the access rights to get Ember properly running.
Edit: Forget what I wrote, I looked at the wrong log
But please try to reinstall the latest release, all other users with your issue no longer has that issue with the latest version.
I have now re-downloaded 1.4.9.1
Installed 1.4.9.1 on top of the existing version
Started EMM
Opened the settings and enabled Collection ID from TMDB within Movies
Right-click on the "Bourne Identity" movie and selected "Rescrape selected movies" ... Ask (...)... All Items
Then it crashes as before, see the log
Dan: Would a complete reinstall and setup of EMM be worth trying?
(in a new folder)
(2020-02-26, 10:57)Cheadstina Wrote: [ -> ] (2020-02-24, 20:21)Cheadstina Wrote: [ -> ] (2020-02-23, 23:42)DanCooper Wrote: [ -> ]Looks like you don't have a proper installation because the IMDb trailer scraper and other already removed modules are still existing. Please reinstall the latest release over the existing one. Don't use the C:\Program Files folder because you've to edit the access rights to get Ember properly running.
Started EMM
(in a new folder)
Why not. You can copy the Profiles folder from your old installation to the new one. You should do that before you've startet the new installed Ember because than the profiles folder isn't existing. As always don't install Ember under Program Files because of the right issues with some kind of Windows user rights.
(2020-02-24, 23:54)shwetkprabhat Wrote: [ -> ] (2020-02-24, 22:38)DanCooper Wrote: [ -> ] (2020-02-24, 21:28)shwetkprabhat Wrote: [ -> ]I set the log level in the advance setting as follows:
<loglevel>1</loglevel>
<setextraloglevel>1024</setextraloglevel>
and fresh logs for:
1. EMM
2. Kodi
Let me know if this helps.
Still can't see any JSON request or db activities in your log. It should look like this:
2020-02-24 21:34:13.225 T:20488 DEBUG: JSONRPC: Incoming request: {
"jsonrpc": "2.0",
"method": "VideoLibrary.Scan",
"params": {
"directory": "D:\\Ember Test\\Filme\\Barry Seal - Only in America (2017)\\"
"id": 3
2020-02-24 21:34:13.240 T:20072 NOTICE: VideoInfoScanner: Starting scan ..
2020-02-24 21:34:13.241 T:20072 DEBUG: VideoInfoScanner: Scanning dir 'D:\Ember Test\Filme\Barry Seal - Only in America (2017)\' as not in the database
2020-02-24 21:34:13.245 T:20072 DEBUG: CVideoDatabase::GetMovieId (D:\Ember Test\Filme\Barry Seal - Only in America (2017)\Barry Seal - Only in America.dvd.mp4), query = select idMovie from movie where idFile=344
2020-02-24 21:34:13.256 T:20072 DEBUG: VideoInfoScanner: Found matching full NFO file: D:\Ember Test\Filme\Barry Seal - Only in America (2017)\Barry Seal - Only in America.dvd.nfo
2020-02-24 21:34:13.266 T:20072 DEBUG: VideoInfoScanner: Adding new item to movies
I believe the following did the trick, I could now see similar logs:
Quote:<advancedsettings>
<loglevel>3</loglevel>
<debug>
<extralogging>true</extralogging>
<setextraloglevel>32,1024</setextraloglevel>
<showloginfo>true</showloginfo>
</debug>
</advancedsettings>
1. kodi
2. emm
DanCooper is the logs have what you were looking for?
(2020-02-26, 11:04)DanCooper Wrote: [ -> ] (2020-02-26, 10:57)Cheadstina Wrote: [ -> ] (2020-02-24, 20:21)Cheadstina Wrote: [ -> ]I have now re-downloaded 1.4.9.1
Started EMM
(in a new folder)
Sadly that resultet in the exact same problem.
Installed EMM to a new folder
Copied the Profiles folder from the old installation to the new clean install
Started the new EMM - and ensured that Collection ID was enabled under TMDB.
Rescraped "Bourne Surpremacy"
Got the same error
log
So either it's something in the Profile folder that's corrupt or something with EMM (?)
(2020-02-26, 22:28)Cheadstina Wrote: [ -> ] (2020-02-26, 11:04)DanCooper Wrote: [ -> ] (2020-02-26, 10:57)Cheadstina Wrote: [ -> ]Dan: Would a complete reinstall and setup of EMM be worth trying?
(in a new folder)
Got the same error log
Just tested with "Bourne Supremacy" in German, English and Danish without any error. The Log shows Ember v.1.4.91. The latest is version 1.4.91.1, but the log can't display the last digit (I've to change that in the next release). So are you shure that you use the latest version of the first post? It's not that I don't believe you, but I don't want to look for bugs that have already been fixed. If you are already using the last version, I would like to ask you to send me your "Profiles" folder as a ZIP (Dropbox or similar). Send me the link as a PM.
(2020-02-26, 22:28)Cheadstina Wrote: [ -> ]Rescraped "Bourne Surpremacy"
Thank you for your PM. I found the bug. It was another really obvious copy-paste error: Link
GitHub
Will be fixed in next release
In looking through my media files I've noticed that I occasionally make typos when naming them. I'd very much like to fix these typos but know that doing so will break the links already saved in EMM. Is it possible to edit the file path for the (Movie, NFO, Poster and Fanart) within the UI?
(2020-02-28, 20:45)pfp-az Wrote: [ -> ]In looking through my media files I've noticed that I occasionally make typos when naming them. I'd very much like to fix these typos but know that doing so will break the links already saved in EMM. Is it possible to edit the file path for the (Movie, NFO, Poster and Fanart) within the UI?
Ember has a build-in renamer. You can enable it under "Settings => Modules => Renamer". If it's enabled you can use "Tools => Bulk Renamer" to show which movie has to be renamed or you can use "Contextmenu => Renamer => Manually" to set a new folder and video file name.
and fresh logs for:
1. EMM
2. Kodi
"jsonrpc": "2.0",
"params": {
"id": 3
<debug>
</debug>
</advancedsettings>
1. kodi
2. emm
Hi @
DanCooper - did you get the chance to look at these logs..
Thank you Dan Cooper for this excellent version, it is working perfectly and still my favorite tool to manage my collection.
You are awesome.
Thanks for the update Dan. I use this regularly.
Does Atmos metadata now get scraped correctly (to show in Kodi)?
(2020-03-01, 10:47)HomerJau Wrote: [ -> ]Thanks for the update Dan. I use this regularly.
I don't think so. I've nothing changed in that part of code. Full Atmos/other advanced audio streams support will only be available in Ember 2.0 because the database need more fields and the metadata scanner needs to be rewritten. I've already done that for Ember 2.0, but I think I can't use that code in Ember 1.5.x without to much changes.
(2020-02-29, 18:40)shwetkprabhat Wrote: [ -> ] (2020-02-24, 23:54)shwetkprabhat Wrote: [ -> ] (2020-02-24, 22:38)DanCooper Wrote: [ -> ]Still can't see any JSON request or db activities in your log. It should look like this:
"jsonrpc": "2.0",
"params": {
"id": 3
<debug>
</debug>
</advancedsettings>
1. kodi
2. emm
Hi @DanCooper - did you get the chance to look at these logs..
How do you use your content in Kodi? Do you've added your sources in Kodi or do you use Plex or Emby to show the Movies?
