2020-03-26, 10:17
(2020-03-25, 13:47)solamnic Wrote: [ -> ]Perfect!!!!!!!!!!! any ETA on v2 ?Not really. But next month I'm only working 50%. I think then I will have more time to work on Ember.
(2020-03-26, 14:20)calexicoca Wrote: [ -> ]I installed v1.5 and all is working fine, except Kodi Interface. In module setting it is enabled and when checked it prompts that connection is successful. However when I try to sync TV show I get red flag and "sync failed".Please check the log for more information.
(2020-03-26, 15:11)DanCooper Wrote: [ -> ]Thanks.(2020-03-26, 14:20)calexicoca Wrote: [ -> ]I installed v1.5 and all is working fine, except Kodi Interface. In module setting it is enabled and when checked it prompts that connection is successful. However when I try to sync TV show I get red flag and "sync failed".Please check the log for more information.
(2020-04-01, 14:44)mnerec Wrote: [ -> ]The version specific link to the forum (top right corner of EMM) links to Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread instead of Ember Media Manager 1.5.x - Discussion Thread.Thx! Will fix that.
2.3.4 moviestacking
Main page: File stacking
This is used by the file stacking algorithm to combine multi-part files and contains a list of "regular expressions". For stacking videos that are contained in folders, such as VIDEO_TS folders, see <folderstacking>
As of v9.11, video stacking regular expressions must contain exactly four (4) capture expressions.
Default:
<moviestacking>
<!-- <cd/dvd/part/pt/disk/disc> <0-N> -->
<regexp>(.*?)([ _.-]*(?:cd|dvd|p(?:ar)?t|dis[ck])[ _.-]*[0-9]+)(.*?)(\.[^.]+)$</regexp>
<!-- <cd/dvd/part/pt/disk/disc> <a-d> -->
<regexp>(.*?)([ _.-]*(?:cd|dvd|p(?:ar)?t|dis[ck])[ _.-]*[a-d])(.*?)(\.[^.]+)$</regexp>
<!-- movienamea-xvid.avi, movienameb-xvid.avi -->
<regexp>(.*?)([ ._-]*[a-d])(.*?)(\.[^.]+)$</regexp>
</moviestacking>
If the argument action="append" or append="yes" is supplied, the default moviestacking regular expressions will remain intact and the user specified ones will be added to the end.
Example:
<moviestacking action="append">
<!-- This expression will match movename1-xvid.avi, moviename2-xvid.avi.
Be warned that it will likely stack sequels in a flat directory layout,
so it is only recommend in a dir-per-video layout. -->
<regexp>(.*?)([ ._-]*[0-9])(.*?)(\.[^.]+)$</regexp>
</moviestacking>
If the argument action="prepend" is supplied, the default moviestacking regular expressions will remain intact and the user specified ones will be added to the beginning.
Example:
<moviestacking action="prepend">
<regexp>(Title)(Volume)(Ignore)(Extension)</regexp>
</moviestacking>
If no argument is supplied, or the argument append="no" is supplied, the default moviestacking regular expressions are overwritten by the user specified ones.
(2020-04-04, 13:09)Thelastninja Wrote: [ -> ]hi your application is fantastic, i use it often, too bad i can't use the new one .... will you make an Ember Media Manager version 1.5.0 for x32?Yes, i also can build a x86 version with the next release.
thanks for everything, greetings
John
(2020-04-04, 13:25)jtm010101 Wrote: [ -> ]Hello I have split movies Ember Media Manager 1.5.0 x64 - Build from 2020-02-29 stacks them well for me, but kodi 18 shows me each part as an independent movie and it doesn't group them together they can help me THANKS….That should work out-of-the-box without any changes in AdvancedSettings.xml. If you take a look to this regex test it worked:
El increíble Hulk (2008) (4k).Part1.strm
El increíble Hulk (2008) (4k).Part2.strm
El increíble Hulk (2008) (4k).Part3.strm
(2020-03-27, 16:33)calexicoca Wrote: [ -> ]"Source no mapped" means your sources in Ember are not mapped to the sources in Kodi. Please check your settings in Ember Modules => Kodi Interface => Host Settings:(2020-03-26, 15:11)DanCooper Wrote: [ -> ]Thanks.(2020-03-26, 14:20)calexicoca Wrote: [ -> ]I installed v1.5 and all is working fine, except Kodi Interface. In module setting it is enabled and when checked it prompts that connection is successful. However when I try to sync TV show I get red flag and "sync failed".Please check the log for more information.
I checked the log and it has there that whatever episode or a move I want to sync I get one of these:
- source not mapped
- not found in database or
- not found on host.
Mind you Ember scans all of these fine. They show on my Kodi (Nvidia Shield) after I refresh library.
(2020-04-04, 14:32)DanCooper Wrote: [ -> ]GRACIAS LPOS E RENOMBREDO Y SIGUE(2020-04-04, 13:25)jtm010101 Wrote: [ -> ]Hello I have split movies Ember Media Manager 1.5.0 x64 - Build from 2020-02-29 stacks them well for me, but kodi 18 shows me each part as an independent movie and it doesn't group them together they can help me THANKS….El increíble Hulk (2008) (4k).Part1.strmEl increíble Hulk (2008) (4k).Part2.strmEl increíble Hulk (2008) (4k).Part3.strmThat should work out-of-the-box without any changes in AdvancedSettings.xml. If you take a look to this regex test it worked:
I had to enable "ignore case" in the tester, but that should be enabled for any multipart regex in Kodi. You can try to rename your files from "Part" to "part" and try it again, but i think there is another problem.
(2020-04-04, 14:32)DanCooper Wrote: [ -> ](2020-04-04, 13:25)jtm010101 Wrote: [ -> ]Hello I have split movies Ember Media Manager 1.5.0 x64 - Build from 2020-02-29 stacks them well for me, but kodi 18 shows me each part as an independent movie and it doesn't group them together they can help me THANKS….El increíble Hulk (2008) (4k).Part1.strmEl increíble Hulk (2008) (4k).Part2.strmEl increíble Hulk (2008) (4k).Part3.strmThat should work out-of-the-box without any changes in AdvancedSettings.xml. If you take a look to this regex test it worked:
