2020-02-23, 22:05
Kodi will not play video from an SMB share in 90% of cases.
I have created the following log file:
http://paste.kodi.tv/uqekaquqam
The lines that I consider important are the following:
2020-02-23 20:16:10.777 T:17374 <span class="hljs-deletion">ERROR:</span> Read - Error( -1, 110, Connection timed out )
2020-02-23 20:16:10.777 T:17374 <span class="hljs-deletion">ERROR:</span> Open - error probing input format, smb://FRITZ-NAS/FritzPlatte/TOSHIBA-ExternalUSB3-0-11/21 Bridges.mkv
2020-02-23 20:16:10.778 T:17374 <span class="hljs-deletion">ERROR:</span> ExtractThumb - Error creating demuxer
I have used the following hardware and software:
Fire TV Stick with Kodi 18.2 (connectet to the router by wifi)
Fire TV Box with Kode 18.5 (connectet to the router by LAN)
Fritzbox 7490 with attached USB storage that is shared by SMB
From my point of view I could limit the problem to the fact that it only occurs in connection with Kodi and the SMB share of my router. For this I have made the following tests:
Playback device: Fire TV stick
Device that provides SMB sharing: Fritzbox
Storage device: USB stick
Result: No
Playback device: Fire TV box
Result: No
Storage device: USB HDD
Result: No
Result: No
Playback device: laptop
Result: Yes
Playback device: smartphone
Result: Yes
Device that provides SMB sharing: NAS
Storage device: HDD
Result: Yes
I couldn't think of any other meaningful test. I tried to solve the problem for several days in vain and searched the internet completely. I must add that the problem occurred overnight. You hear this very often, but I wouldn't know anything that has changed.
Ask me anything you want to know. I'm grateful for any information.
Result: No
Result: No
Result: No
Result: No
Result: Yes
Result: Yes
Storage device: HDD
Result: Yes
