Full Version: KODI 19 - Best way for implement HW Audio Decoder (HW Video Decoder is OK)
Pages: 1 2 3
(2020-07-03, 04:20)leandrotsampa Wrote: [ -> ]Hi, I'm using STB Atto Pixel (SoC: Hi3798Cv200) but I will add compatibility with STB Atto Pixel Premium (SoC: Hi3798Mv200) too.
Hi Leandro, very good project!
I have an Octagon sf8008 (SoC: Hi3798Mv200).
Your releases will be restricted to Atto Pixel Premium or will be compatible with other Hi3798Mv200 STBs?
Thank you,
sdf
(2020-07-03, 11:07)sdfg Wrote: [ -> ]
Thank you,
sdf
Hi, thanks.
Can work with other's STBs, but probably will need some fixes to work Tuner, RC and Front Display.
(2020-07-03, 13:00)leandrotsampa Wrote: [ -> ]
Thank you,
sdf
Hi, thanks.
Hello Sir
how would you plan to make it work on STb ?
we dont have Android in Octagon and other STb Huh
will your plugin install Debian on it ? and android Huh
M.O
(2020-07-02, 23:55)Midozalouk Wrote: [ -> ]How did you loaded Enigma2 from Debian ?
or you need to switch between them ??
All this is very simple, I put Debian without interface and install all the rest as a systemd service.
And yes, from Enigma2 you can open KODI or RetroArch (and can install anything in Debian too ;P).
You can change to boot KODI with TVheadend or RetroArch if you not want Enigma2.
You can see more info here: GitHub
Do you lose android with this script ?
i see it allows you to dual boot android with enigam2
where is Debian ?
do you support dvb sx2 or not ?
will i e ale to install libreleec o it ??
sorry for the may Qs?
(2020-07-03, 20:52)Midozalouk Wrote: [ -> ]Hello Sir
M.O
Installation process is in GitHub or in Site and it's already working.
It's a Dual Boot like any other.
(2020-07-03, 21:00)leandrotsampa Wrote: [ -> ]
M.O
you mean just using this command
dd if=/media/sda1/e2d-armhf-pixel.img of=/dev/mmcblk1
i think it wont work on stb
Huh
(2020-07-03, 23:00)Midozalouk Wrote: [ -> ]
M.O
Huh
It's to write sdcard.
To enable dual boot need apply e2d-armhf-pixel.upk by Android or Recovery mode, but this file is for STB Atto Pixel.
(2020-07-03, 23:32)leandrotsampa Wrote: [ -> ]
(2020-07-03, 21:00)leandrotsampa Wrote: [ -> ]Installation process is in GitHub or in Site and it's already working.
Huh
Hello Sir
i have searched for the specification of atto pixel premium but i couldn't find it Sad
can you help me with it Huh?
how may tuner it haves and its type  ??
(2020-07-18, 00:14)Midozalouk Wrote: [ -> ]Hello Sir
Hi, I think is base on U5-PVR because when analysing firmware can get some info about it but not use tvheadend.
You can check some info here: https://www.atto.tv/atto-pixel-premium/
Details:
1x USB 3.0
1x USB 2.0
1x microSD slot
1x AV socket
1x S / PDIF optics
1x HDMI 2.0a, HDCP 2.2, HDCP1.4
1x LAN connector RJ-45 10/100/1000 Mbps
2x 2.5 GHz / 5.8 GHz dual band antenna
1x 12 V, 2 A power connection
SoC: Hi3798Mv200
NAND: 8GB
RAM: 2GB
GPU: Mali450
SO: Android
Sorry for inconvenience
But FERGUSON U5 PVR don't support 4k Netflix
Can you please tell me how many tuner it haves?
And what about tuner sensitivity?
Thanks sir
(2020-07-21, 01:51)Midozalouk Wrote: [ -> ]Sorry for inconvenience
Thanks sir
Is it type dvb s2 or sx2?
(2020-07-21, 01:55)Midozalouk Wrote: [ -> ]
Thanks sir
I'm not know about netflix, but have some videos on YouTube maybe you can find some usefull.
1x DVB-C Triple
2x DVB-S/S2
In DVB-C sensitivity is good and DVB-S/S2 I'm not know.
Hello sir
Any updates on how to install it to other STBs
Thanks sir
(2020-02-24, 05:28)leandrotsampa Wrote: [ -> ]Hi guys, I'm working on my hisilicon STB SoC Hi3798Cv200.
I maked a full rootfs Debian Buster for developer and added Enigma2, RetroArch and now KODI 19-alpha.
For now, I added support for HW Video Decoding on KODI and it's working good and I want add HW Audio Decoder too but my problem is, if I add support in DVDCodecs\Audio how I can handle AddData function? is possible get Audio ES?
Info
Whitout HW Video Decoding
With HW Video Decoding
Hi, I have a duosat next fx lite with the same soc, is it possible to install it on it? I really want to use enigma2 on the device
(2020-02-24, 21:11)da-anda Wrote: [ -> ]You know that KODI does support PVR and retroArch kernels to play games, right? So instead of basing everything on Enigma you could just directly run KODI and basically do the same. Yes, there is no games library yet, but instead of working on this odd hybrid you could work on the games library as well Smile
Indeed, KODI's support for PVR and RetroArch kernels for gaming is impressive. Emphasizing KODI's capabilities and developing a dedicated games library could enhance the overall experience, attracting more gaming enthusiasts.
Pages: 1 2 3
